The XJ-S will be SORN at the end of this month and as I have had a minor whiff of petrol in the boot for quite a long time, this winter I intend to pull the tank, clean and check everything carefully.
I'm thinking that due to the age of the (original) hoses I might have replacements made up by my hydraulic specialist using modern materials. The insulation pad might also need replacing and it may be an idea to look into a suitable drain cock for the bottom of the swirl pot.
I will update as it goes but it may take some time as its not my main priority at the moment.
Hose replacements suitable for E10
