I had the usual ABS/Trak warning lights come on intermittently on my 2001 XK8.
Jaguar Forums have discussed this topic and described the repair.
Had the module removed and yes there were hairline cracks on the soldered joints, very difficult to see with the eye!
Now repaired and all ok.
Contact Richard Millar at Berwick Service Station, East Sussex on 01323 870598.
Steve
ABS Module Repair
Black XK8 2001 4.0L V8 Convertible
Black X-Type 2008 3.0L V6 Sovereign Estate
Re: ABS Module Repair
Useful to know, I get the same intermittently, I don't suppose you are able to post a link to the repair procedure by any chance?
XF Sportbrake 2020 / XK8 1998
You need to use a Code reader to determine what part of the ABS System is at fault
Try to rule out the various parts by substitution (cables & sensors) - Front ABS Sensor Cables are same
Also Cruise Control Brake Switch can also cause Fault Messages but not identified by Jag System - Switch off Cruise Control from Central Console & see if Error Messages continue (If you don't clear Fault Codes with a Reader it takes a few no fault starts to clear system)
ABS Unit can fault in Electrical &/or Valve parts. I'm told that they are matched units & should not be replaced separately.
It is true that the X100 suffers from dry/poor solder joints in the various electrical modules. However, the other parts of the ABS system are less reliable.
AllanJ
AllanJ
XK8 Registrar
Thanks Allan, at present warning has gone so I am ignoring it, but I am sure it will come back soon! I find the obd much less useful than it was on my X150, on that it even told me which abs sensor was faulty, but no such detail on a 98 xk. I gather that obd technology was progressing at pace during the lifetime of the X100, so I suspect later cars are able to provide more information.
I concur with Allan's guidance above, however, there's no doubt that the OBD in the earliest X100s was somewhat limited. By the later model years, with a diagnostic reader such as AutoEnginuity, most modules, sensors and many switches can be observed directly in their mode of operation.
The most common problem with ABS modules is the dry solder joint syndrome, often where the main power leads feed the circuit board, but a sort of keyhole surgery solution has been developed . It's a remarkably simple process that might tempt many a keen owner to give it a go if diagnosis suggests it being appropriate. Best of all, there's no cost to giving it a go
It can be seen here on the ever useful JagRepair website
http://www.jagrepair.com/JaguarABSUnitRemoval.htm
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
