The viscous fan on my 1986 V12 is sadly deceased. I am now thinking of replacing this with a Kenlowe fan . Has anyone done this and if so what fan do you reccomend. Help greatly appreciated. Sorry I am new to this and have just discovered where I should have posted this thread.
Cooling fan upgrade
Cooling fan upgrade
This might get you started
http://www.jag-lovers.org/xj-s/book/ElecFan.html
I have no experience in this at all but I'm sure someone with a V12 will add some suggestions.
Cooling fan upgrade
i have fitted an electric fan to my V12, it was actually quite easy once i had figured out how o mount it
i did do a thread on the subject a few years back with pictures
remove all the viscous fitting parts , this will mean a modified bolt on the original engine mount ,
then mount your new electric fan to the original cowl by making some ' tangs ' in the cowl lip that let the supplied plastic mounts fix to it, i'm afraid only a picture will allow this to be understood
i will see if i can dig one out
then you will need a power supply, and thermostatic control of the fan
the electric fans are at least five times better than the viscous original
Cooling fan upgrade
here you go
http://www.talkphotography.co.uk/galler ... Small_.JPG
darrenxj-s
Cooling fan upgrade
Thanks for your help, I have purchased a Kenlowe fan with fitting kit,switch etc and will fit it when it arrives thanks again all.
