Which Battery Isolation Switch? Bypass 123 Dizzy!!!
davgr01
Postby davgr01 » Tue May 18, 2021 12:42 pm
Hi All
I recently had to buy a new battery for my 65 S-Type and after 3 weeks it was flatter than a pancake!!!.
I'm going to get an Isolator Switch fitted so does anyone know of the following:-
Decent Isolator Switch I could Use?
Is it easy to bypass the 123 Distributor so I can leave the Immobilisor on?
What drain does the 123 Dizzy have on the battery when the car is left idle?
Graeme
piman
Re: Which Battery Isolation Switch? Bypass 123 Dizzy!!!
Postby piman » Wed May 19, 2021 10:30 am
Hello Graeham,
the simplest is the type that clamp onto the battery post, and take a feed from the battery clamp side via an inline fuse to anything you want to keep energised.
An example here, which has the fused line included :- https://www.holden.co.uk/p/discarnect_p ... ter_switch
