Just when you thought it was safe...
again thanks to Paul and Keith et el.
In light of the previous tests I bought a brand new 100A 950 cca yuasa 5000... top one IMHO.
I started her up, ran fine but engine amber warning light still on, so plugged in my cheap OBD reader, code 1606 came up.
That indicated ECM RELAY so bought another.
In the meantime I reinitiated the parasitic drain test and to my horror straight after shutting her off I noted a 3-4 amp pull which was way more than before. I disconnected her overnight.
The next day oddly enough after reconnecting and starting, the engine light disappeared but I replaced the relay anyway. (Incidentally the part no. Changed from LJA6703AA to T4N15704, I can recommend David Manners who are very helpful.)
Once she was running I had no warning lights , checked charging voltage = 14.2, was ok - (considering base was 13.3) - same on Rev to 2000 Rev on neutral. Tells me alternator is charging ok?
However after shutting down I then put the multimeter in series again, draws 4.9 amps !!
Reconnecting and start again, put multimeter in AC MODE and checked for AC across terminals.
Shows “0.000V” for a second, then “92.000V” and every second it flips, assume it’s because it’s AC?.
From that, I presume now I have a worn out or wearing out alternator /diode? Brush? which intermittently shows that it is failing, creating havoc with electrical circuits, relays, causing the AC reading which it should not have, right? This then leads to the diode leaving circuit open and then the ECM thinks to keep everything on, leaving a drain.
Being in failure mode, it may explain why sometimes it’s ok at 0.026 and other at 4.9A..
I’m probably now gonna order a new alternator, she needs a service anyway so I’ll get it fitted then.
If anyone can recommend a good supplier for the alternator that would be appreciated..I looked at jaguar and they take the **** at £879 and I’m sure they can be had for less than £200?
Unless I’ve missed something !!
