X100 Window Waist Seals
SilverXKR
Postby SilverXKR » Sun Oct 04, 2020 4:20 pm
An article in the October issue of the magazine will no doubt be well met by many X100 owners.
Unfortunately, the author (Andrew Barrington) didn't provide an eBay link to the product and I haven't been able to trace it.
Hopefully, Andrew will pick up on this post and provide said link. Thanks Andrew in anticipation.
Ken Ward
2016 XJ 3.0 Ltr Portfolio
2000 XKR Silverstone
2010 XF Portfolio (Sold)
JimMann
Re: X100 Window Waist Seals
Postby JimMann » Sun Oct 04, 2020 5:08 pm
It can be noted that JLR Classic claim to have XK8 waist seals in stock now for £106.25 including VAT, which is still significantly more expensive than the eBay option, but it is an OEM part. Link will take you to parts.
https://parts.jaguarlandroverclassic.co ... -seal.html
Jim
Jim Mann
Banchory
Andy P
Postby Andy P » Tue Oct 06, 2020 11:14 am
Hi Ken,
This might be the item in question.
Jaguar XK8-R Door Window Trim Rubber Seal.
The seller is "rtay5993" and has good feedback on the item,here is the link:
https://www.ebay.co.uk/itm/Jaguar-XK8-R ... %7Ciid%3A1
Andrew Barrington must of purchased two which would be near the £40.00 he stated they cost.
Or this one,but it seems to cheap and not the right bit anyway:
https://www.ebay.co.uk/itm/Jaguar-XK8-F ... %7Ciid%3A1
Hope this helps a bit and good luck with your waist seals.
Take care.
Andy :D
JimMann
Postby JimMann » Tue Oct 06, 2020 10:14 pm
Hi, Andrew has confirmed that his eBay supplier is on the link below. He also notes that he will be at Castle Combe on Oct.20.20 and if anyone is there he will be happy to show off the fix and talk to others.
https://www.ebay.co.uk/itm/Jaguar-xk8-x ... 4423502573
Jim Mann
Jim Mann
Banchory
SilverXKR
Postby SilverXKR » Tue Oct 13, 2020 8:35 am
Thanks go to Jim, Andrew and A.J.P for the links. Hopefully, there may be a member or members that can benefit from Andrew's kind offer should they be at Castle Combe. In any event, the links will be useful to members in solving this common problem.
Ken
mikeanson
Postby mikeanson » Mon Oct 19, 2020 11:01 pm
Jim
Note:
These are the inner waist seals, not outer.
