Hi I own a 2017 F Pace Jaguar 3 litre diesel the car is running really well apart from one small niggle. When you have been driving for 10 mins or so the car emits a single 1 beep alarm. I can't see any reason for the alarm and wonder if any member can point me in the right direction, or if the car has a fault, the warranty on the car expires in September so I am keen to know if it is a fault.
Stuart Bentley
F Pace alarm beep
Moderators:jBlackwell, mike020150
Re: F Pace alarm beep
As described, it sounds (pardon the pun) a little odd to me. These days, there are alarms for all sorts of things in modern cars. Have you checked the handbook to see if something you have done (like turning off the passenger airbag or some other safety system) isn't accompanied by a periodic warning beep? Otherwise, I'd suggest contacting your dealer. Mike.
stuart_bentley788
Hi Mike, thanks for responding, I have checked the handbook and can't see anything re. this, I will check with the dealer, i was hoping to avoid that under the current circumstances.
Stuart
Stuart
