Press Studs
Moderator:LJR
Hi guys where can I find a supply of press studs that hold the door cards on the door??
Re: Press Studs
Not all press studs are the same and I think you will find they varied slightly across the different series cars. For example, there are three different part numbers for the studs fitted to series 2 cars. The usual trim/parts suppliers advertising in the magazine can usually provide equivalents even if they can't supply the exact clips Jaguar used. Mike.
