Spark plug change today at 79k miles.
Applies to V8 4.2 Jaguar models with perhaps some engine dressing differences between X350, S-type, XK8 and XF both supercharged and non supercharged variants. With minor differences, the job is not dissimilar to the procedure used on the earlier 4 litre V8 models. 4.2 models have pull off covers which make matters easier than 4 litre cars which tended to have bolt down covers fitted. 7mm spanner needed to release the covers on 4 litre engines.
The procedure is as follows.
Remove the spark plug covers to access the plug on coil packs. 8mm spanner to remove a single lock down bolt on each coil. Press at the back of the electrical connector plug to separate from the coils. This is the press down tag adjacent to where the electrical wires enter the plug. This job can be a frustrating fiddle on the rear two cylinders on both A and B banks as the engine is tucked well back towards the front bulkhead and space is limited.
Gather a variety of 14mm plug sockets, extensions and universal joints. A foot long length of 1/4" bore rubber fuel hose is useful to remove spark plugs from their wells once they have been screwed out of the cylinder heads. Plug changing on the front cylinders is easy enough but the back cylinders are obstructed by various pipes and fittings. On the right hand side bank as you look from the front of the engine to the rear is very obstructed and coil removal is very tight indeed. Tip the top of the rear coil backwards towards the bulkhead to gain removal clearance. On the next cylinder forward, extract the coil upwards through the EVAP pipes and two air con pipes. That is the only way it can be got out. A bit of a nightmare. Difficult but not impossible. Allow a couple of hours for the job.
Plug gaps should be 1mm. At nearly 80k miles the removed plugs had eroded to 1.5mm so were definitely past their prime. A small trace of copper grease on new plug threads helps new plug fitting and is most useful as an anti-seize compound when you next come to change the plugs.
Any difference after the work? Yes, certainly, particularly noticeable on initial throttle pick up away from a standing start. The car is generally a little more lively as a result of the plug change. Worth doing even though misfires were not present. All part of preventative maintenance and increased reliability.
Spark plug change. 4.2 V8
Re: Spark plug change. 4.2 V8
May I ask for your guidance as to how to get around the various obstacles on the passenger side please?
I believe I need to remove the pipes shown red and blue - and also get the yellow-marked wiring bundle out of the way to stand a chance of lifting the plugs... are the pipes safe to disconnect and will I need any special tool/clips to re-assemble? I can't see any single termination connector for the wiring bundle, so moving that seems unlikely.
I wonder whether you could offer guidance please?
Short clip showing location in case the photo isn't clear - or if mine is somehow different to normal...
https://youtu.be/EINA3_tJskI
That particular set up is fresh territory for me.
Ideally you do need to clear as much clutter as possible to gain working space. Its very tight at the back of the near side rocker cover so get as much peripheral gear out of the scene. Pipe clips can be a nightmare to separate and possibly need a few special tools to split them. Electrical plugs again can bend your brain finding out how they fix together. You will need some cunning for removing that rear plug as well as a piece of 1/4" bore pipe to extract the plug once you have worked your ratchet, extension bar and socket out of the plug well. A simple plug change on these cars can develop into an ordeal.
All I can say is that you need to gather as many hints, tips and wrinkles together from various sources. I recall removing that rear plug took me as long to do as changing three others which were vastly less obstructed.
You can depressurize the fuel system by pulling the fuel pump fuse. This will save spraying fuel everywhere when you eventually get the pipes apart.
Without seeing the car personally, I`m afraid I`m relying totally on memory from several years ago.
Perhaps Astromog or Brian might be able to offer further advice.
Hi Jeremy,
What year is your car? My 2006 (3.5 Sport) is rather different in layout compared to your pictures. It may be an illusion but it seems like your fuel line (blue bit in your photo) has been tied into the main engine cable loom (the yellow bit in your picture)? If so, then it does not make any sense to do this and I wonder if that is ex-factory or if a previous owner has done this. The (red) fuel line should be a loose pipe in its own right with just the coupling in the middle. The main engine loom (yellow) is held onto a bracket low down at the back of the engine by a tie-wrap. This can be cut to move the loom away to get more access (make sure to replace it later)
I have taken a picture of my car for reference but I can't work out how to upload it as I don't use cloud storage or file sharing sites etc. I can PM this to you if that's the only alternative.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
Previous XJs:
It’s a 2004 model so perhaps some changes...?
I’d appreciate a photo PM, thank you!
Jeremy
Jeremy
