Hazard light indicator
Moderator:LJR
njk1963
Postby njk1963 » Tue Jan 14, 2020 8:46 pm
I have an unusual problem with the indicators on my series 2 coupe
When I indicate left the hazard light indicator flashes
The indicators are working as they should so it’s more of an annoyance than a problem
I’ve changed the hazard relay and the switch is wired as follows
#1-Light green/blue wire
#2- Light green/white wire
#3- Light green/red wire
#4- Light green/green wire
#5- None
#6- Light green/pink wire
#7- green wire
#8- Brown/orange wire
Has anyone else had this problem and been able to solve it?
Cheers for any help
Re: Hazard light indicator
Postby mike020150 » Thu Jan 16, 2020 10:18 am
There should be a diode in each indicator lamp circuit to prevent such phenomena so it may be that these are missing/been mis-wired or similar. Mike.
