cloudy headlight
I have a cloudy headlight on my 1977 (R) XJS. Have tried removing it and swilling out with methylated spirits, that works for about 30 seconds, but then slowly clouds over again ? anybody had the same problem ? can these be repaired ? or anybody got a drivers side for sale ?
Previous cars
1977 XJ-S V12 Pre-HE (28 yrs)
2000 S Type 2.5 (company car)
Current car
1989 XJ-S V12 Convertible
2023 Range Rover Evoque (Hybrid) (every day car)
Current car
concretefingers934
Re: cloudy headlight
There are tons of how to restore cloudy headlights on you tube . I have restored headlamps with the kits and it works.
https://www.carbibles.com/best-headligh ... tion-kits/
Why is it cloudy? Residue within the light or something on the outside?
These are glass lenses so not prone to clouding through uv degradation as plastic ones are.
Hi David, The cloudiness is on the inside, we have tried removing the light and swilling out with methylated spirits, that works perfectly, but within a minute or two clouds over again.
Previous cars
Current car
Current car
I assume you have Fishermas Friend Lozenge headlights? Try a small amount of cellulose thinners, that generally works as a solvent where alcohol based ones won't work. Safe on glass, but not on plastic lenses as used in other Jaguar models.
If still no joy, the lenses can be separated from the silvered backs although this is a last resort.
Al
Al
Thank you Al it worked. If you ever see a bright yellow 1977 XJS, reg BFV702R, at a JEC event, remind the driver he owes you a pie or a pint regards Richard
Previous cars
Current car
Current car
