Side repeater
Linda
Side repeater
Postby Linda » Wed Mar 20, 2019 6:33 pm
My side repeater has a broken clip, I have bought a new one, can you tell me how I remove the electrical element to put it into the new repeater. I do not want to force it off and break it, just wondered if anyone had a magic tip for me.
JimMann
Re: Side repeater
Postby JimMann » Fri Mar 22, 2019 1:42 pm
Helpful to know what vehicle you are asking for assistance with? Year would help as well as model. Cheers.
Jim Mann
Banchory
Linda
Re: Side repeater
Postby Linda » Fri Mar 22, 2019 3:43 pm
xk8 1996. Should have said .
Re: Side repeater
Postby mike020150 » Mon Mar 25, 2019 3:12 pm
From memory, once you have accessed the rear of the repeater by removing the under wing access panel, the bulb/holder/wiring can be removed either by twisting or squeezing the casing. Then, the repeater lens is extracted by pushing the unit forwards or backwards to compress one of the springy legs and simultaneously pulling the uncompressed end outwards. Mike.
aaj
Re: Side repeater
Postby aaj » Mon Mar 25, 2019 6:18 pm
Linda
It's about 10 years since I replaced one of these Bulbs.
From my sketchy memory, there are 2 little lugs on the Bulb Holder & you rotate the Bulb Holder by 90 degrees to release it from the Repeater Body.
AllanJ
XK8 Registrar
Linda
Re: Side repeater
Postby Linda » Tue Mar 26, 2019 9:39 am
Many thanks, it came away easier than I thought it would and I managed to change the bulb without disaster :D .
