Borg warner model 8 gearbox
Moderator:cstorey
Galaxiecammer427
Hi all, I'm a new member, and am hoping that someone out there might be able to help me.I have a'68 420G with a Borg Warner model 8 gearbox. It will not go into third gear. I have had the gearbox rebuilt, the company has had the car on close to six months, and they still cannot get it to go into third. Ithink the problem is outside the actual gearbox. The gearbox place has replaced all the clutches, and the valve body, and the pump. Is there any way that a 4.2xj6 box can be installed?
DaveNeedham
Re: Borg warner model 8 gearbox
Kick down cable too tight?
- RichardSEL
FWIW part way through the production run of XJ6 series 1, gearbox was changed from BW12 to BW8 -- I don't know the reason. Is your plate like this?
What's the name of this firm? (so I know who to avoid
The workshop manual lists 12 possible causes of failure to upshift from 2-3. The only listed cause I can see that is outside the gearbox is "Manual linkage incorrectly assembled or adjusted".
Six months is an awfully long time. Perhaps it may be time to take the car elsewhere?
Robbie
Robbie
Daimler Sovereign S1 4.2 1971
rogersouthern626
Ok, I'm late to the party and you may have resolved the issue by now, but.. My experience with the Model 8 was on the VdP 4 Litre R and I had the same thing after it was 'tuned' at a local garage. The kick-down/throttle sensor cable had been vastly shortened by them (why?) and 3rd wasn't for engaging below about 80 mph. Disconnected cable, wound it out to virtually max extension and refitted. Nearly perfect change but still needed a half turn (and they are that sensitive) to achieve perfection. Worth trying if you're still stuck.
