Aftermarket Parking Sensors
RMA37
Postby RMA37 » Fri Jan 11, 2019 5:24 pm
I'm thinking of putting aftermarket parking sensors to my 1997 XK8 Convertible. I'm so used to all the warnings and camera on my current BMW, I find reversing the Jag very tedious!
I found one that fits behind the bumper from Parking Dynamics which requires no holes etc. as I don't want to alter the looks of the car in any way. I would be interested to hear from anyone who has fitted something like this. Would make a good winter project if they are any good.
Thank you
Astromorg
Re: Aftermarket Parking Sensors
Postby Astromorg » Sat Jan 12, 2019 12:00 am
I've got one fitted on the front of my XK8, Jaguar having kindly fitted a standard system to the rear, and it's OK. It's not as precise as the ultrasonic type, but it does avoid the disfigurement aspect, particularly on the front bumper of an XK8.
And if having fitted it you don't like it, it's easily removed without leaving any scars!
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
RMA37
Postby RMA37 » Sat Jan 12, 2019 9:51 am
Thanks for your response. Did you fit it yourself?
Astromorg
Postby Astromorg » Sat Jan 12, 2019 12:20 pm
Yes. Not difficult, just a bit awkward running wires through the car and, of course, knowing which wires to tap into!
Wiring diagrams are here if you don't already have them
http://www.jagrepair.com/images/AutoRep ... xk1997.pdf
2024 XE 300 Sport
RMA37
Postby RMA37 » Sat Jan 12, 2019 1:21 pm
Thanks so much for your help. Might need to ask later where exactly the feed goes. I'm think of fitting rear and front sensors. I see they are on offer at the moment on ebay.
andypryce
Postby andypryce » Sat Jan 12, 2019 5:49 pm
I fitted one that goes around the number plate on my old X300. Ok it only has 2 sensors on it, at either side of the number plate, but it worked well and was easy to fit, splicing it into the reverse lamp wire. I am pretty sure you can still get them, have a look on eBay.
XF Sportbrake 2020 / XK8 1998
