BAC6236
xjs1996
BAC6236
Postby xjs1996 » Sat Dec 15, 2018 8:13 pm
Hi Folks,
Does anyone know where the above can be sourced - not having much luck.
JCP's dont stock any more.
TIA
Peter
Tintin
Re: BAC6236
Postby Tintin » Sat Dec 15, 2018 9:19 pm
A Google search for "wing piping" may yield some material you may be able to use.
Robbie
Daimler Sovereign S1 4.2 1971
xjs1996
Re: BAC6236
Postby xjs1996 » Sun Dec 16, 2018 12:37 pm
Thanks will try.
xjs1996
Re: BAC6236
Postby xjs1996 » Sun Dec 16, 2018 2:02 pm
https://www.coh-baines.co.uk/products/P ... iping.html
Would the above be of any use ?
The size quoted online is 31x0.7x0.7 cm a hollow pipe
The above is 0.8cm with a tail .
Thanks for any input
Peter
Tintin
Re: BAC6236
Postby Tintin » Sun Dec 16, 2018 4:06 pm
I have just had mine out to measure it. The uncompressed diameter is 6.6mm and the compressed "bead" above the panel surface is 3.2mm - there is no flat "tail" so most/all of that will need to be cut off with a sharp knife. The site you quote offers several different sizes but the stuff is cheap enough to buy a couple of lengths to trial fit.
Robbie
xjs1996
Re: BAC6236
Postby xjs1996 » Mon Dec 17, 2018 9:45 am
Many Thanks Tintin.
xjs1996
Re: BAC6236
Postby xjs1996 » Mon Dec 17, 2018 2:24 pm
Robbie
Robbie,
The restorer has advised '' I'm sure I need them on then wings tightened then chrome on around the window '' is that correct regards when they are to be fitted?
Would you happen to know the inside diameter?
Have seen this https://www.amazon.co.uk/black-rubber-c ... s=7mm+hose
Thanks,
Peter
Tintin
Re: BAC6236
Postby Tintin » Mon Dec 17, 2018 6:37 pm
My apologies - I hadn't realised the work was being done by a professional restorer - in which case you should leave it all entirely to him.
All I can say is that one of mine went missing this summer, and when I get round to it in the New Year I certainly won't be removing the wing and/or windscreen finishers to fit a replacement. Whether that is the "correct" way or not I can't say.
Robbie
xjs1996
Re: BAC6236
Postby xjs1996 » Tue Dec 18, 2018 12:42 am
Robbie
Not a problem, glad of your input.
Struggling to find replacements in UK, there is a pair in Holland....but they have advised they can not find them in the warehouse.
There is a pair in the States, a copy of they are selling ...but, at best a week though now in the Christmas rush.
What came out was a rubber seal and the other side a ''distorted straw'' as was described.
Job in hand was scuttle replacements, almost done, its getting put back together......window out , chrome off in doing so.
He measured the i/d and it was 4mm, have bought the hose on Amazon and we shall see how it fits.
This is the first time he has done this job, I gathered a lot of information from various sources and got all the parts together.
But, this part that I requested turned out to be the seal that goes under the windscreen chrome - so - I needed this sourced and quick.
Question was if he could put back together and then pop the seals in, but I will have them soon so its a cover bet and hopefully as it sounds a part fit for purpose.
There is nothing doing UK wise with these seals/fillers by the looks of it .
Thanks again for you input.
Peter
Tintin
Re: BAC6236
Postby Tintin » Tue Dec 18, 2018 10:01 am
Parts that were NLA are gradually being re-introduced by Jaguar, SNGB and others where there is demand and there is no alternative. For this particular application I would have thought a generic seal would have "done the job" - just a question of finding something suitable and, to a certain extent, working out your own installation method.
I assume form your "tag" the car is a 1996 Celebration? It would be nice to see some photos!
Robbie
xjs1996
Re: BAC6236
Postby xjs1996 » Tue Dec 18, 2018 11:12 am
Robbie
Was a post from Years ago pointing to JCP's having, they no longer have but have filled in form stating they should reintroduce them.
Britparts put me onto www.the parts.com - states of having 2 in Holland but they can not find them in the warehouse.
Shop on Ebay in USA are making them as no availability in UK.
As it stands I believe the wing is yet to be tightened and the chrome is off - it is with the repairer.
Must mind and post when I get it back!
Peter
PaulGover
Re: BAC6236
Postby PaulGover » Sun Dec 23, 2018 12:46 pm
On my car, it's just a length of piping with a tail (cross section's a bit like a sperm) to fill the gap between the centre and side panels. I reckon you might be able to duplicate it with a short length of tubular draft seal (B&Q used to sell something appropriate) sprayed with plastic primer and top coat. I don't recall how it's fixed - you might need glue.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
