hi there,
my cruise control has stopped working. it was fine then stopped working suddenly. any ideas? Regards Scott
cruise control
Re: cruise control
It could be a loose connection or a leak from the bellows amongst other things.
Re: cruise control
Hi Scott - it would be helpful to know some more details about your car as there are different systems.
For example, earlier V12 cars had the econocruise system and the usual culprit is the bellows in the vee that actuate the throttle. This seal between the end plates and the rubber bellows breaks down. Taking it apart and resealing with some silicone will usually do the trick. Otherwise look for a vacuum connection that has perished or fallen off.
Later cars used the Kliekert system and the usual fault there is the dump valve sticking open.
Hope that helps
Hope that helps
Re: cruise control
For later cars, another failure mode is perishing/wear of the silicone washer that links the bellows pushrod to the throttle linkage.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
2021 I-Pace SE
Johnscotty22
Re: cruise control
Thanks, sorry its an 89 v12.. turns out it seems to be a loose connection on the throttle cable sensor..
Thanks again
Thanks again
