Windscreen wiper spindles' grommet
Moderator:LJR
RichardSEL
Postby RichardSEL » Wed Sep 05, 2018 7:56 am
On the XJ6 series 1 was there ever a grommet between the windscreen wiper motor spindle and it's surrounding scuttle? There wasn't anything on mine when I got it but there does look to be one grommet of sorts in one of the pix I took at delivery:
Re: Windscreen wiper spindles' grommet
Postby mike020150 » Fri Sep 07, 2018 11:02 am
Try viewing the JLR Classic parts book (www.jaguarclassicparts.com/catalogue/da ... ical/#p=26) where you can see the grommet/seal. Mike.
PaulGover
Postby PaulGover » Fri Sep 07, 2018 7:34 pm
Dunno 'bout the Series 1, but by Series III it had a rubber thingy. I think it was purely cosmetic; at least, I had only one, but neither wiper showed problems.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
RichardSEL
Re: Windscreen wiper spindles' grommet & Wiper park switch
Postby RichardSEL » Sat Sep 08, 2018 10:24 am
Thanks for the replies...
Yes, series 1 chassis '72
I couldn't see for looking. It's on the parts' diagram for the motor and drive spindles as C5574 available on eBait as "Wiper Spindle Grommet" at £2.48ea +£1.50 p&p from ANG 02476 565 708
And while I'm down here, the "Wiper Park Switch" (described as "discontinued" from the big suppliers)
is 12453 @ £10.50 ea
Tintin
Postby Tintin » Sat Sep 08, 2018 7:23 pm
C5574 is a wiper rack TUBE grommet - it seals the point where the actuating mechanism passes through the engine bulkhead. The series 1 wiper spindle seal assembly is C28005 (within the dashed box in the parts diagram). I doubt this will fit the wiper spindle/scuttle joint of the Sedanca - its scuttle is a different profile to a series 1 car.
Robbie
Daimler Sovereign S1 4.2 1971
RichardSEL
Postby RichardSEL » Sun Sep 09, 2018 9:15 am
Thanks Robbie :roll: I've already ordered them now. Oh well, they'll also double as cable grommets and weren't expensive. I've got a spare set of aerial grommets too that I've left with the paint shop. Hopefully one of them will fit suitably cut down.
Meanwhile, with your helpful info, info I'll have a look at C28005.
<later> That number comes up on Martin Robey's site as for a "bolt". Another site gives it for the whole drive spindle holder
... it's only a hobby, only a hobby, only a...
Tintin
Postby Tintin » Mon Sep 10, 2018 4:39 pm
AFAIK C28005 is NLA but the listed part may not fit anyway. It may be possible to fabricate something with rubber washers, a short length of splay cut pipe as a plinth and a suitable lock nut. The joys of owning rare cars!
Good luck.
Robbie
