Coolant leaking alarmingly
Johnscotty22
Postby Johnscotty22 » Mon Aug 20, 2018 11:01 pm
Hi there. I parked my 89 5.3 v12 up toady after some spirited motoring,during which all guages were good,temp,oil.When I got back to the car there was coolant pouring out from around the steering rack area.
As soon as it had stopped I refilled the system (3 ltrs) expecting it to pour out,It didn't. I then drove it 10 miles temp guage was normal. no loss of fluid. parked up and fuiid started pouring out again..
Any Ideas??
Scott
davidr
Re: Coolant leaking alarmingly
Postby davidr » Tue Aug 21, 2018 7:25 am
Is your expansion tank rusted and leaking? It's on the left side chassis rail.
Another possibility are the water rails that run along both sides of the engine.
davidr
Postby davidr » Tue Aug 21, 2018 7:30 am
By the way, be very cautious about driving your car if you have cooling system issues. The golden rule with these alloy V12's is "Don't cook it!" They can respond very badly to overheating with warped heads, dropped valve seats etc all a distinct possibility.
