Petrol pumps failure
RREED
Postby RREED » Sat Aug 08, 2015 10:07 pm
My 1999 xkr spluttered and stopped last week. I understand that this model has a primary and secondary pump. Jaguar quote £150 each. Does anyone know if there is a cheaper source?
Re: Petrol pumps failure
Postby mike020150 » Sun Aug 09, 2015 9:30 am
Not noticed one but if you find an alternative, it would be good to share the knowledge. Mike.
Postby J44EAG » Sun Aug 09, 2015 12:36 pm
British Parts list one at around £57.
http://britishparts.co.uk/products/7838 ... mp-C2N3866
wombat
Postby wombat » Tue Apr 10, 2018 11:33 pm
Thanks Mike K, even though the post is from 2015 still got the fuel pump at £65. Just need to fit it now!
Still on track to get it back on the road for Classic Le Mans.
1999 XK8 Coupe
2009 LR D3
Both make me smile :D
X200ROG
Postby X200ROG » Wed Apr 11, 2018 3:38 pm
It's worth changing both pumps while you're about it. I had both of mine changed when one failed. I didn't do the job myself, but I understand you can get to the pumps via the rear parcel shelf - much easier than removing the petrol tank
Rog
Growing old is inevitable - growing up is optional, so live each day like it's your last 'cos one day, it will be
Anthracite 2001 XKR coupé with lots of bling
XJR308
Postby XJR308 » Wed Apr 11, 2018 5:14 pm
Is the Primary pump just for starting that just gives a squirt when the ignition is switched on?
Bruce
davidr
Postby davidr » Wed Apr 11, 2018 7:18 pm
I've changed the pumps on my 2001 car and it was far from easy to do with the tank in situ! You'd need to be double jointed and have eyes on stalks! I found it easier in the end to take the tank out (which is straight forward apart from undoing the "quick release" fuel connectors from underneath). This gave me the chance to flush the accumulated detritus from the tank too.
wombat
Postby wombat » Wed Apr 11, 2018 7:36 pm
Have already removed the parcel cover and have access - very tight and as you said you double jointed. Will try this way first when the new pump arrives.
I have only a single pump as it is a MY99.
1999 XK8 Coupe
2009 LR D3
X200ROG
Postby X200ROG » Wed Apr 11, 2018 7:37 pm
Bruce
It's the secondary pump that is used for starting the engine, and also for augmenting the the A pump when Wide Open Throttle conditions are used.
Rog
XJR308
Postby XJR308 » Wed Apr 11, 2018 8:02 pm
So if it starts but won’t run the secondary pump will be okay?
How would you check it is not just the relay?
Bruce
X200ROG
Postby X200ROG » Thu Apr 12, 2018 10:19 pm
Bruce
I wouldn't know the answer to that question Bruce. A code reader may identify whether the relay has failed though.
Rog
Postby mike020150 » Fri Apr 13, 2018 9:40 am
Relays are notoriously difficult to check other than by substitution. Mike.
XJR308
Postby XJR308 » Fri Apr 13, 2018 11:43 am
Would it not then be wiser to replace the relays before replacing the pumps?
Bruce
Postby mike020150 » Fri Apr 13, 2018 2:21 pm
With supercharged models running two pumps and two relays, it's possible either to swap relays or 'borrow' one from another working function to test them. Mike.
XJR308
Postby XJR308 » Fri Apr 13, 2018 4:13 pm
Yes Mike
That is what I would do when the time comes. However the OP is replacing his pump with no mention of checking relays and has been advised by others to change both pumps while he is at it! How red will his face be if it is only a relay that has stopped working?
Bruce
