Instrument Panel Bulbs
Milan
Postby Milan » Thu Jun 19, 2008 12:58 pm
Hi everyone,
The handbrake bulb on the instrument panel on my facelift XJS is gone (I just see the yellow "bulb gone" warning light when I activate the handbrake). How easy (or more likely, extremely difficult) is it to replace this bulb? I've checked the drivers' handbook and there's no mention, so I'm guessing it's far from straightforward (like most things with the XJS!).
Cheers,
Milan.
Green 94 XJS 4.0 Facelift
nigel1
Postby nigel1 » Thu Jun 19, 2008 3:25 pm
The bulb failure light will come on when the hand brake is applied and the brake pedal is pressed. I do not think it monitors the instrument warning lamps.
Changing the bulb is pretty easy.
If I remember right, the procedure is this:
Remove the two phillips head screws (one each side of the cluster on the trim).
There is a third screw at the top bit of the trim, remove that as well, and then remove the trim. In the upper corners of the instrument cluster are two removable bits of plastic, they will prise out (carefully with a thin bladed screwdriver). Under these, are two more screws, remove these, and then gently pull the cluster out far enough to access the two multiplugs at the back of the cluster (oh, and drop the steering wheel to lowest position). Disconnect the two multiplugs, and thats the instrument cluster free to come out.
The bulbs need a quarter turn to remove.
I would first try swapping the suspected blown handbrake lamp with a another warning bulb, and then reconnect the instrument cluster and test the function of the bulb with the handbrake. If the lamp does not come on with the handbrake, I would suspect that the microswitch at the base of the handbrake is duff
