Rear Wishbone
toolsisme
Rear Wishbone
Postby toolsisme » Sun Dec 31, 2017 1:51 pm
Hi ,Can anyone tell me the correct way round to fit the rear fulcrum bolt washers (steel & nylon) i had to use heat to remove the bolt and didn't notice how they were fitted.They don't make sense to me either way and workshop manual doesn't show and i can't find anything in the usual places.
Thanks Rob
Re: Rear Wishbone
Postby mike020150 » Mon Jan 01, 2018 10:07 am
Is the car an XK8 or an XK? Front or rear, upper or lower wishbones would also help to ensure you get the best advice. Mike.
toolsisme
Re: Rear Wishbone
Postby toolsisme » Mon Jan 01, 2018 11:30 am
HI Mike.Its a 2001 XKR convertible rear lower part number MNG2960AA/61AA and the washers are MMB2882AA x 4
Rob
davidr
Re: Rear Wishbone
Postby davidr » Mon Jan 01, 2018 12:04 pm
Rob - does this image from Jaguar Classic Parts help? Part number 5 is the washer you gave the part number for.
toolsisme
Re: Rear Wishbone
Postby toolsisme » Mon Jan 01, 2018 6:04 pm
Hi David.No thanks i have that and the workshop manual but neither shows the way round they go .eg plastic side to bush or metal side to bush.
Thanks again
Rob
Re: Rear Wishbone
Postby mike020150 » Tue Jan 02, 2018 1:20 pm
Very helpfully, the workshop manual says, 'Ensure the correct orientation of the flat sided washers'. However, logic suggests that the plastic washers are probably there to keep water and dirt out of the wishbone bushings so, in the absence of more definitive information, I'd fit them that way around. Mike.
toolsisme
Re: Rear Wishbone
Postby toolsisme » Tue Jan 02, 2018 2:14 pm
Hi Mike.yes i agree with you and that is the way I've fitted them but the nylon washers just float around and seem to serve no purpose.That is why i am confused,all logic and looking at the remains of the old parts seem to indicate that is the way round but when fitted they just don't look right.
Many Thanks
Rob
toolsisme
Re: Rear Wishbone
Postby toolsisme » Mon Jan 08, 2018 10:53 am
The final word on this is that the nylon washers face the bushing.David Marks has kindly checked on several cars for me and can confirm this.Thanks again for everyones help with this matter.
Rob
