Glove Box Availability
xjscharlie
Hello Folks,
Just an oddball query, my 94 X300 does'nt have a glovebox passenger side as does the X350 and i wondered if the interior paneling above the footwell had any possibility of being interchanged and if anyone had ever done this? Or if a glovebox option was ever fitted to later models. Appreciate there may just be a swift NO on this but you never know as its often surprising what gets interchanged between models. Regards. Charlie.
PeterDavisX300
Re: Glove Box Availability
The early X300's had no glove-box. Mines an early 1995, and has a tiny box that is of virtually no use. I think you can retro fit them.
1984 Mercedes 450SL Rag-Top
Is it because there's an airbag behind there?
Certainly in the later XJS the space previously occupied by the glovebox became an airbag. I wonder if in the change from XJ40 to X300 the same happened?
xjscharlie
The airbag is behind the wooden facia at the top but i was wondering if it was possible to install below that with the same or similar paneling to the X350. Charlie.
Dimensionally, the 350 is a rather larger car than 40/300/308, Charlie.
I think you might be quite hard pushed to install a glove compartment from a 350. I can give you height and width sizes if you wish. I think you would be into some major cutting and shutting with such a conversion.
early 300 did not have a glove box
it was introduced from Feb 1995 from VIN 739427
however , due to lots of customer complaints many cars were retro fitted, and many have also been done privately
its easy, plug and play as it were
get your trim code, and find a breaker, lots about, I have some here, with the same colour and just remove the old knee bolster and refit the glove box unit
Just be aware the lid has a lock, so your key will lock it , BUT NOT open it, so check that the unit you buy is unlocked, or has a key, or you get the VIN of the donor car to get a key cut
Hope this helps Rob Jenner
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
xjscharlie
Many Thanx,
Could you advise where i can find my trim code? Rgds.
passenger B post label
or
front radiator slam panel on a label
or
post a picture, we can probably work it out as there were not many 300 trim colours
or
send me your VIN and I will ask Jaguar
cheers Rob
or
or
or
cheers Rob
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
xjscharlie
Hello Again,
Believe i found the code on label on radiator panel. It says TRIM HEZ AK. Could you advise colour.
Thanx in anticipation. Rgds.
HEZ is Parchment, of course a rarer colour!!
all trim codes here
http://www.exclusively-jaguar.co.uk/fac ... rim-codes/
all trim codes here
HEZ dye listed and available from this seller.https://www.google.co.uk/url?sa=t&rct=j ... mKMGF3lmZm
three pics of a glove box removed from the car
10 minute job to swap over
this one was in the depths of my stash hence it needs a good clean, I have two more, no keys but all unlocked
if one is of use let me know £40.00 posted (quite chunky items)
xjscharlie
Many thanx for the informative replies, i'm sure i'll be able to sort it. One has to wonder why Jaguar did'nt include it in the first place as the X300 is the only Jag i can think of that did'nt have a glovebox. Charlie.
Late 40 and XJS didn't eitherMany thanx for the informative replies, i'm sure i'll be able to sort it. One has to wonder why Jaguar did'nt include it in the first place as the X300 is the only Jag i can think of that did'nt have a glovebox. Charlie.
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
I've seen late 40's fitted with 300 glove-boxes by the owners though at a later date
