Supermarket diesel
Moderators:Popsjag, J44EAG
PaulGover
Supermarket diesel
Postby PaulGover » Wed Dec 13, 2017 1:13 pm
I wonder if anyone else has similar experience of supermarket diesel as me?
I normally use the cheapest stuff locally, which is usually Sainsburys', except in summer when I'll throw a few tankfuls of Shell V-Power through, as I believe it helps clean the exhaust system and filters (particularly the DPF).
My last-but-one tankful, just at the start of autumn, was Tesco's cheapo. I had problems starting, almost as bad as a maladjusted petrol engine on a cold day, and for the first 5 mins a nasty exhaust note and it felt like it was running on 5 cylinders. Then I went back to Sainsburys' cheapo, and no problems at all; starts on the turn of the key, runs smoothly. Bad luck hitting a bad batch, or is Tesco's often noticeably worse?
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
PPV
Re: Supermarket diesel
Postby PPV » Wed Dec 13, 2017 1:35 pm
Don't know about different quality of diesel but I have water in my previous diesel cars when using Tesco to fill up. Had to have tank drained but could not prove it was them as the source. Have avoided ever since.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Postby J44EAG » Wed Dec 13, 2017 11:01 pm
Perhaps a wise idea to obtain some Dry Fuel additive from a motor outlet. I think Halfords stock it.
Dry Fuel additive will allow small amounts of tank water to combine with diesel fuel which can then be burnt off in a diesel engine without causing damage. It is a Bosuns Locker "must have" in the marine industry. I never put to sea in a boat without fuel tanks being dosed with the additive.
rosemary
Postby rosemary » Sat Dec 16, 2017 12:49 pm
Hello All
As a matter of interest firstly I bought a new petrol mower this year all lovely and shiny, assembled it at home and went off up to the local Shell Garage and got a gallon of petrol in my dry can. Put it in to the mower and do you think it would start, it would not. New machine so I phoned the supplier to return it. Advised to take it to a local mower service agent 10 minutes from my home. Arrived at service agent and explained the problem, he had a look straight away, removed the plug and immediately proclaimed water in the petrol!!!. He drained the tank and showed me 1 inch of water in the bottom of the container he had drained the tank in to. New petrol in tank and mower started first pull, all is well except I had to pay him for his work as it was not a Warranty Job, it was only a tenner any way so wasn't bothered mainly relieved.
Secondly my neighbour used to work for ASDA and in the office he often saw the fuel invoices in for payment for the attached fuel station. Fuel was delivered in ASDA tankers and the Invoices were paid to ESSO.
Dave Hart
greyhair
Postby greyhair » Sun Dec 17, 2017 10:43 pm
I Try and always put Shell Nitro diesel in our car . I May be kidding myself but i think the car is more quiet . i don't think Mpg is very different.
I have only been doing this for the last 12 months or so prior to that i would sometimes use supermarket fuel or ordinary diesel from one of the main retailers as well as the premium fuel.
