Winter Boredom!
Popsjag
Winter Boredom!
Postby Popsjag » Thu Nov 30, 2017 9:19 pm
I was a bit bored, so I thought I might make another grill for 'Red' !
I cut the centre section out and enlarged the height of the opening by a few millimetres top and bottom.
It should look quite smart at night!!
I will not be fitting it yet as there are a few areas that need touching up :shock: , when the weather is a bit warmer.
2003 X350 XJR - daily driver
Past vehicles:
PeterDavisX300
Re: Winter Boredom!
Postby PeterDavisX300 » Fri Dec 01, 2017 7:59 pm
Hey, I like that. I've got a spare chrome grill, I think I'll have a go at that at work, where did you get the Stainless - Steel mesh? I think I'll put a matching (Proper-Jaguar) wheel centre in the middle of mine.
Peter
1984 Mercedes 450SL Rag-Top
Re: Winter Boredom!
Postby J44EAG » Fri Dec 01, 2017 8:41 pm
He is my mod on an X350 with 70mm ebay sourced growler badge. It is a bit of a take on the later X358 grill.
The grill on the X350 is glass fibre so machines well. I made a circular plinth from e-glass and epoxy cast inside a Holts spray can lid. Removed from the lid, it was then cut it to profile with a Dremel type unit with a miniature cutting disc.The plinth was then epoxied to the grill surround and blended in with an epoxy/easy sand filler powder. A bit of blending to profile with glass paper gave the basis of the job followed by four coats of primer, a flat down and five coats of matching spray paint. Once dry, it was wet flatted with P1200 W&D paper and polished up with G3. That done, the badge was stuck to the finished grill surround with car number plate adhesive tape.
Only three images...that tedious site limitation again!
Popsjag
Re: Winter Boredom!
Postby Popsjag » Fri Dec 01, 2017 11:16 pm
Peter,
The grill is actually black ABS honeycomb - cut to size.
Mike,
Nice work!
Past vehicles:
