Daimler V8 250 saloon oil pressure relief valve
djpeters23140
Postby djpeters23140 » Wed Sep 20, 2017 9:42 pm
Hi all. I have decided to try and improve my hot low idle oil pressure which is about 10-15 psi at 600 RPM. I have changed the big end bearings and I am replacing the oil pump relief valve. I was surprised to find the existing valve has a small hole through the centre which would allow oil to pass through even when closed under spring pressure. The new David Manners one does not have such hole. Has anyone found the same or has a theory. Dave
1967 Daimler V8 250
1979 Honda CBX1000Z
1974 Suzuki GT750M
