seems that fingazfobz not contactable or even still exist any one got any clues and or an alternative please. my 2 fob packed up within 2 days
of each other strange i know. one origional 2nd new ish replacement for a lost one. both owned at least 2 years. batteries replaced rgularly.
getting to be a pain in the b.. main reason dont know if they work or not as wont reprogram. well versed on the procedure for 2002 xj8 se.
however when using keys manually petrol cap doesnt always unlock. any advice welcome.
key fob repairs!!!
- RichardSEL
Re: key fob repairs!!!
This worked for me, hope it helps?
Key Fob re-Programing for XJ6 and XJ8
The battery is a single CR2032 cell that’s placed positive (+ is the bigger side diameter) down into the plastic battery bottom (not the buttons’ side), of the FOB’s case.
Early FOBs have the prefix LJA, whilst later cars use the LJE version. The programing technique is quite straightforward:
1, Make sure that little flap in the ignition barrel closes inside the hole -- if it is sluggish or stuck then a little lock lube and working the key in and out a few times usually does the trick. This flap must be shut otherwise the locking module will think there is a key in and not allow the system to go into learning mode.
2, Get into the car with the key and remotes to hand and make sure ALL doors, bonnet and boot are properly closed.
3, Pull the headlamp flasher stalk towards the steering wheel and hold there.
4, Now put the ignition key in and turn to position 1 (ACC with no dash lights on)
5, Release the headlamp flasher and flash FOUR more times -- the tell-tale LED on the left of the “J” gate gear selector should flash ONCE
6, Now press the lock button on the remotes a total of FIVE presses (one remote 5 times, 2 remotes, 3 on one and 2 on the other etc. The “J” gate LED will flash at each button press.
7, Remove the ignition key and the “J” gate LED will flash ONCE more as it is taken out.
markcollins
thanks richard stupid boy mark!!!!! starting process with key in ignition oops not out of it. guess i will be up early to try it all over
again. best have a glass and a good nights kip. so stress free before hand. cheers.
