Leaking Heater Valve - Suggestions?
LHR
Postby LHR » Sat Jul 08, 2017 8:56 pm
Put coolant in my car today. Fortunately no leaks so far with the exception of my new heater valve. I understand that the original seal may not be available any longer. I used a single "O" ring which I thought would do the job but it obviously has not. I did not use any type of sealant between the mounting face on the heater box and the valve. Perhaps I should have?
I would appreciate any suggestions or tips on how to deal with this issue. Thank you!
Lin
Lin
1964 Jaguar MK2 3.8 MOD currently in restoration
1959 Austin Healey Sprite Frogeye
1960 Austin Healey 3000 MKI BT7 - first car I ever owned and still have it!
1969 MB 280SL
1987 Alfa Romeo Quadrifoglio Spider
piman
Re: Leaking Heater Valve - Suggestions?
Postby piman » Sun Jul 09, 2017 7:40 am
Hello Lin,
as it is a simple design, my thought is that the 'O' ring is the wrong size, either in diameter or the section of the 'O' ring is too small? Using a high temperature silicone sealant would probably do the job but I don't like that route.
oldtimer
Postby oldtimer » Mon Jul 10, 2017 10:52 pm
Lin,
I don't recall an annulus machined into the valve face to take an O ring.
I would suggest you obtain some gasket material and jointing compound like Red Hermatite or Hylamar from say Halfords.
Remove the valve and use the valve mounting face as a template to cut out a new gasket. Draw around with a Biro and down the mounting holes and cut out using a new blade in a Stanley knife. A thin application of jointing compound to both sides of the new gasket and reassemble.
Job done
LHR
Postby LHR » Sat Jul 15, 2017 4:29 am
Got the proper "O" ring from Terry's Jaguar. Fit like a charm and no more leaking. I can't explain why the one I had was undersized but I am pleased that I now have the proper one in place! Thank you to respondents.
Lin
Lin
1969 MB 280SL
oldtimer
Postby oldtimer » Sat Jul 15, 2017 10:07 pm
Lin,
That's interesting, is there an annulus into which the "O" ring fits ?
piman
Postby piman » Sun Jul 16, 2017 6:06 am
Hello Oldtimer,
in the distant recess of my memory. a 45 degree shamfer on the face of the valve where the O ring sits?
