Hi, my second post regarding my XJ.
When my DAB radio is on and I switch on the heated rear window the radio goes off! When the heater is switched off the radio comes back......weird to say the least.
Has anyone had this issue previously?
XJ DAB radio
Moderator:ct575
- raysearles
Re: XJ DAB radio
Not heard of that before now - but as all the gibbons for the DAB radio is under the plastic cover in the middle of the upper rear window sounds like there is a fault or a short on one of the connections - under warranty still ? (is used ex Jag dealer?)
- raysearles
Re: XJ DAB radio
trickymicky
Re: XJ DAB radio
Thanks Ray, the car is booked in for a once over and thankfully under warranty. Technology is good but a pain when it goes wrong. I'll post the results if its fixed.
trickymicky
Re: XJ DAB radio
Problem rectified, a replacement rear windscreen was fitted.
