IRS Strip Down and Rebuild
This is a picture from earlier in the thread of the driveshaft attached before the lower wishbone, hub etc.
And here's a closeup of the shims between the brake disc and driveshaft.
Re: IRS Strip Down and Rebuild
there is some well proven advice to remove said shims to improve the handling of the IRS on the XJS , for a more positive feeling and better turning in
I seem to recall that being said many years back.
Of course , what is important is to ensure the camber angle is equal on each side.
David R, I can't quite see with the camera angle but are those nuts in safety ?
Oldtimer
PS I hope you've put the Duvet through the wash before her indoors finds out !!
Oldtimer
PS Forgot to say, Posh job , well done
Thanks Oldtimer - sharp-eyed as ever!
The picture was taken before the nuts were tightened to better show the shims in place. They were tightened up later!
That's not the wife's duvet the cage was sat on but part of my extensive collection of raggedy old towels I keep in the workshop.
Occasionally (when she who must be obeyed has her attention elsewhere) I do sneak them in for a trip around the washing machine. This does not improve marital relations and can result in a loss of privileges if I'm caught!
David R. I know the feeling but sadly her in doors is no longer with us but still get the feeling she is looking down on me so I haven't got my engine roll over frame in the lounge yeeet !!!
the duvet is for when he has to sleep in the garage...........
fully agree, equal measurements all round for any setup , or at least to original spec ,
will the XJS be coming to Kemble in just over a weeks time ?
BB - yes I will be bringing it to Kemble but that depends on the weather for 2 reasons. Firstly if it's too wet and mucky I will leave it tucked up warm and dry - I don't want it covered in muck and salt!
Secondly, the sunroof has stuck open!
sunroof ?
i don't remembering it having a sunroof ? a steel one ?
mine is a glass one, and i only ever saw one for sale about ten years ago, and nothing since, i hope it never breaks
rknowles74
Each shim being worth 0.25 degree is really useful information. I was getting concerned that my basic maths would have been stretched trying to work that out.
The next step is to find someone able to rebuild my diff.
Cheers,
Richard
Cheers,
Richard
do you have the ' manual winding tool ' for the sunroof ?
Just (nick picking) (where did that daft saying come from ? ) Now where was I ,Oh yes , for the benefit of all , the nuts securing the disc and drive shaft must be all steel self locking nuts . These used to be called Oddie nuts. Under no circumstances use nylock as this area gets hot from the discs. Finally, self locking of any kind should never be used a second time. Do a free running torque check and see the difference between new and old. Here endeth the lesson of the day
I think the motor is behind in the roof area and not in the head rail so I guess I will have to remove the headlining to get to it - that's my weekend sorted then!BB - yes I will be bringing it to Kemble but that depends on the weather for 2 reasons. Firstly if it's too wet and mucky I will leave it tucked up warm and dry - I don't want it covered in muck and salt!
Completely agree. As I said earlier in this thread!Just (nick picking) (where did that daft saying come from ? ) Now where was I ,Oh yes , for the benefit of all , the nuts securing the disc and drive shaft must be all steel self locking nuts . These used to be called Oddie nuts. Under no circumstances use nylock as this area gets hot from the discs. Finally, self locking of any kind should never be used a second time. Do a free running torque check and see the difference between new and old. Here endeth the lesson of the day
Went for MOT today and the result was ............ straight pass! No advisories. The tester declared the car to be "immaculate".
He was that keen to talk about the work I'd done on it that I thought he was going to make me an offer! However he said his wife would kill him if he came home with it!
He was even impressed that the handbrake worked because "the handbrakes on all old Jags are s**t".
So a good result and the immaculate verdict is one I can live with!
Once I had the pass certificate in my hand we couldn't resist teasing the MOT tester about the couple of small things he missed!
The IRS has settled in very well and the car drives much better now. I've been giving it a bit of use this week and the whole car has benefitted from a bit of exercise. For example, there were a few moans and groans coming from the front suspension that had me thinking my next project would be a front subframe rebuild but daily use throughout this week has settled it all down and now it's quiet again. Of course I can now hear the less obvious noises and little rattles which I will have to hunt down and kill!
I've also a suspicion that the pinion seal is weeping a bit so I'll keep an eye on that.
