Brake light switch
The brake light switch on my Mk2 recently gave up the ghost and I need to replace it. I've bought a new one but it didn't come with any gasket or sealing o-ring. Does anyone out there know if there should be one fitted as I don't want to remove the old switch without having all the bits necessary to fit the new one.
Re: Brake light switch
After the original finally packed up I fitted anew one from one of the regular suppliers, it lasted a few years and went again last year. I then bought two and fitted one (one kept as a spare), they don't seem to have much life now!
It is quite simple, quick and easy to change them, I wrap the thread with PTFE thread tape (available from any plumbers merchant). Use a spanner to hold the pipe mounting 'tee' or is it a 'cross' steady and another to loosen the pressure switch. Then unscrew the old and IMMEDIATELY screw in the new one, if you are quick enough then there is no need to bleed the hydraulics.
Just put a bit of rag below the mounting to catch any slight spillage and save your paint.
Depending on the age of your original switch you may have to fit spade connectors to the terminals.
Best wishes
PS It is worth connecting the two wire together to check that your lights work and it is the switch that is at fault?
Best wishes
Many thanks for the advice. I am reasonably confident the switch is at fault as, when switching on and depressing the brake pedal, the brake lights work. On subsequent depressions, however, the lights fail to come on until the switch has 'had a rest'.
I suppose it could possibly be something in the brake pipe which allows the switch to operate at first but then blocks the fluid at any further depressions of the pedal.
stuarthardy
Brake light switches are a big problem now and it seems yet another reproduction item is of poor quality. They have a reputation for failing early.
The E Type boys all seem to be changing to pedal mounted switches by using a reliable plunger switch mounted on a small bracket under the dashboard. I'm in the process of making one for myself.
Might be worth considering.
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
1962 E-Type FHC
1994 X300 XJR
