Interior light delay and wipers
champsdete
Postby champsdete » Sun Dec 23, 2007 10:44 pm
Having started the car from a booster, probably shouldn't have but I was desperate, the interior lights don't go out - at all! I know the delaly relay is powered by a fuse feed but don't know where the relay is or the fuse. Any one help? Also the wipers are very slow-always have been so not related to the first problem. Gerry.
almcl
Postby almcl » Mon Dec 24, 2007 11:00 am
It might be useful to know which model year ? Things do move about a bit over time.
On the 93 (facelift) cars the interior delay module is just to the right of the rhs fuse panel.
Al McL
poprivet
Postby poprivet » Mon Dec 24, 2007 4:53 pm
If the wipers are slow, something is binding. Most likely culprits are the shafts which are sealed with O rings which eventually let water in and the grease out. A sure sign is that the wipers don't park as low down on the screen by themselves, but will with a little help from yourself.
Best to service them soon before the motor burns out.
Pop
Mark_B
Postby Mark_B » Wed Dec 26, 2007 7:15 am
:idea: my guess is the interior light staying is not caused by the boost start but was the reason the battery went flat.
XJ-S 3.6 230k miles +
