XJ S2 Sealed Beam Head lamp
Moderator:LJR
LJR
Postby LJR » Wed Sep 07, 2016 3:16 pm
One of my inner 5.75" sealed beam light units has failed. I have swapped it over with the other working one to make sure it isn't the wiring. Finding another sealed beam light appears to be impossible (unless anyone can suggest where to find one) although the easiest solution. I rarely drive the car at night or even dusk so don't really need to convert to Halogen but this appears to be my only option. Can anyone tell me:
1. what model Halogen light would have originally been optional (Daimler Double Six Coupe)
2. what wiring modifications would be required
3. recommend a supplier given the multitude of offerings that appear to be out there. (original of aftermarket)
Daimler Double Six Two Door
Jaguar XE R-Sport 2.0 Petrol
Daimler Double Six Two Door (Sold)
Daimler Six X300 (Sold)
PPV
Re: XJ S2 Sealed Beam Head lamp
Postby PPV » Wed Sep 07, 2016 6:15 pm
Hi, have you tried Staffurd Vehicle Components Ltd ? (http://www.s-v-c.co.uk/). They do manufacture lights and may be able to help.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
oldtimer
Postby oldtimer » Wed Sep 07, 2016 10:21 pm
Stoneleigh is coming up in October, that might be a good bet
Postby mike020150 » Thu Sep 08, 2016 11:18 am
The optional inner halogen lamps are also getting more difficult to find these days. They were, unsurprisingly, made by Lucas and were convex faced with the word 'HALOGEN' stamped in the centre in white lettering inside an ovalish ring. No wiring changes were necessary. Mike.
richardpierce
Postby richardpierce » Fri Sep 09, 2016 9:57 am
Go to Jagcats at Bell Lane Ackworth, see Les and he will have one
Otherwise I may have one
Richard
Postby mike020150 » Fri Sep 09, 2016 10:09 am
Yes, Les has one of most things! Knowing that LJR lives somewhat further south than we do, it's probably not quite so convenient for him to collect a sealed beam unit from Jagcats. Mike.
richardpierce
Postby richardpierce » Fri Sep 09, 2016 10:22 am
No problem but he has plenty
Richard
BCD
Postby BCD » Sun Oct 23, 2016 5:03 am
Hi. If you cannot get one in the UK email me and I will give you the address of a contact in Australia who has a supply. Email address is brian.devlin@xtra.co.nz
LJR
Postby LJR » Mon Oct 31, 2016 5:51 pm
I managed to source a pair of 5 3/4 NOS and a pair of good used 7in sealed beams from Collector Car Parts near Heathrow. However, am still on the lookout for original Halogens.
Mike, in the parts catalogues the diagram for the halogen headlights shows 'Lucas European' being the emblem on the glass face inside an arrow pointing downwards. I've seen some of these for sale. Do you recall them ever being a period fitment or was it always the Halogen white oval?
Postby mike020150 » Tue Nov 01, 2016 10:23 am
Hi Lucas,
The 'Lucas European' marking only appears in my parts book as the type of lamp supplied to countries (except N America) which took neither the sealed beam nor the halogen units, in other words they were the good old-fashioned bulb variety not used in the UK by that time. Rather like writing 'fuel injection' on the rear of series 2 cars, 'halogen' was one of the latest things in motoring allowing Jaguar to proclaim its technical modernity so it's not surprising to see it plastered across the optional lamps. The fad soon ran out of steam and series 3 halogen lamps were different again. Mike.
JaguarBreaker
Postby JaguarBreaker » Fri Mar 03, 2017 4:53 pm
Old sealed beams whether New Old Stock or Secondhand can be a problem. The filament can oxidise causing white smoke to fill the light and render them useless. It may be caused by a seal deteriorating over time and allowing air to get in. We used to test them when we put them on the shelf and again at point of sale and a lot would fail at the later date. For info I've no longer got any left.
