IRS Strip Down and Rebuild
Re: IRS Strip Down and Rebuild
Postby Brakebuster » Sat Oct 29, 2016 2:11 pm
quick quiz
who can spot the deliberate mistake in Davids last photo,
and its not the iRS in the back of a Rover...
BB :wink:
Postby ptjs1 » Sat Oct 29, 2016 3:56 pm
BB,
The fact that only 2 of the V-mounts are on the cage?
And, although it's a little bit difficult to see in the photo, being REALLY picky, I think I'd like to see a few more threads coming through the locknut on the lower spring and shock mount bolt.....
Iain-1980
Postby Iain-1980 » Sat Oct 29, 2016 5:33 pm
Deliberate?
Dont let him off the hook! ;)
'93 4.0 Coupe, Flamenco red.
davidr
Postby davidr » Sat Oct 29, 2016 9:41 pm
BB,
The 2 rear V mounts weren't on there to make it easier to slide the whole thing into the back of the Land Rover. They were put back on once I got it down to Hollygrove.
Lower shock mount bolt - a good point but not the actual "deliberate" mistake - right area though!
davidr
Postby davidr » Sat Oct 29, 2016 9:47 pm
quick quiz
BB :wink:
I'll offer you 2 quotes
"Well done men! I was wondering which of you would be the first to spot that!" (Captain Mainwaring, Dads Army)
Or
"D'oh!!!!!" (Homer Simpson)
I'll leave it to you to decide which is the most appropriate! :oops: :oops:
Postby Brakebuster » Sat Oct 29, 2016 9:52 pm
if it were me, i would balls it out with the first quote
and don't let anyone say otherwise, lol
BB :wink:
davidr
Postby davidr » Sat Oct 29, 2016 9:55 pm
For anyone wanting a further clue!
Postby ptjs1 » Sat Oct 29, 2016 10:03 pm
Ah! Washer tabs not peened over!
Also, I have a washer before the locknut on the lower spring and shock pin (although mine may be different!). Also, I can't see the splitpin fitted in the hub nut, but that could just be the photo.
Still a valiant job!!
Postby Brakebuster » Sat Oct 29, 2016 10:05 pm
erm , don't look so close, like the tie bar mounted in front of the radius arm mount preventing its installation....
David got quite a bit of ribbing about it this morning , but all in good humour as he has executed a stunning refurbishment
davidr
Postby davidr » Sat Oct 29, 2016 10:46 pm
Washer tabs - they will be bent over when the radius arms are fitted.
Split pin is not in - haven't fully torqued the hub nut up yet as nothing to push against! I'll do it on the car.
Question to ask yourself is how am I going to get the radius arms on? :oops:
Postby ptjs1 » Sat Oct 29, 2016 10:55 pm
David,
it's very honourable of you to 'fess up when you could have just explained that it was in situ merely for photographic and educational purposes! And it doesn't detract at all from the excellent quality of the work you've done. Whereas when I forgot to install the clutch release bearing on my Vitesse gearbox when I was 19, that really was a screw-up!!
davidr
Postby davidr » Sun Jan 08, 2017 11:34 am
It's in!!!
Spent all day yesterday swapping the old IRS for the rebuilt one at Hollygrove.
It took about 2 1/2 hours to take the old one out and was very straightforward as the exhaust is fairly new so came apart easily and everything had been copper greased when I last put the IRS in so I didn't have to fight with anything.
Putting the new one back in took longer of course. The trickiest bit was getting the radius arms square on the body mounting before putting the bolt up through. The temptation is to get it on there roughly and pull it up with the bolt but it doesn't go into much and it's all too easy to strip the threads. That's the benefit of having a professional at your side!
Other time consuming parts were checking the pipe work in the tunnel (fuel feed and return), swapping a few parts from the old IRS to the new, getting the exhausts back into proper alignment and finally bleeding the brakes.
There were also various things that I had left to tighten up until the IRS was on the car and I had something to push against.
So about 2-3 hours to take the old one out and 4-5 hours to put the new one back in.
I'm pleased to report that the drive home was much quieter than the morning drive.
The old diff looks completely shot! When I drained the oil there was so much metal on the magnet of the drain plug! I could also grab the pinion flange and wobble the pinion shaft around! At the very least the pinion bearing has completely disintegrated and I won't know how bad the crown wheel and pinion are until I open it up for a post mortem (which will be fun!)
A more detailed account with pictures to follow.
So, at last, my rear end is smooth and quiet again! :D :D
Enormous thanks to Will Everett at Hollygrove in Ringwood (01425 477000) - having his facilities, knowledge and help (or was I helping him?) made all the difference.
Postby Brakebuster » Sun Jan 08, 2017 12:09 pm
well done buddy , a major task indeed that is now going to enhance the drivability of your car no end
i too ' struggled ' with the radius arms to body , they seemed about an inch short when offered up , and you think something is wrong, but it highlights exactly what they do and why they are there, and its to square everything up , i used a jack to gently lift and push over the cup on the body , this worked well for me on the garage floor , as there was no way the arm would fit with the car in the air , i think the cage has a tendency to roll away from the mount when there is no weight on it
looking forward to the pics
davidr
Postby davidr » Sun Jan 15, 2017 4:06 pm
So here's how it went.
Started by taking the exhaust off. It's a stainless Bell system that I put on about 4 years ago and so it all came apart without a fight.
Here's the joint between the centre section and the over-axle pipe. The mess on it is burnt oil that came from the diff pinion seal.
Undoing the clamp between the over-axle pipe and the rear box.
"Persuading" the back box off with a hide mallet
These all came off without drama - which was good!
Next was the radius arms. First was to take the ABS sensors out of the hubs.
Undoing the screws that hold the ABS sensor looms in place - usually these just shear off - mine were good as they'd been copper-greased.
The loom is also cable-tied to the radius arm - this has to be cut.
And then the ABS sensors can be removed
davidr
Postby davidr » Sun Jan 15, 2017 4:27 pm
Radius arm bolts up into the body can be an absolute b****r to get off. Water tends to collect in that part of the body and they rust in. And once you've got the bolt off getting the large bush to detach from the body can be a real battle. However, I put this IRS in about 7 years ago and there was plenty of copper grease applied in the knowledge that I did intend to do this swap in time so it was my own blood, sweat and tears I was saving!
The lock wire that goes through the radius arm bolt and around the safety strap has to be removed. (PS check this on your own car. It is a safety related item designed to stop the bolt shaking out and so is an MOT fail if not there)
And then the safety strap is unbolted from the body and the radius arm bolt removed.
And then if you're lucky (or you've taken the precaution of copper-greasing it before) it will come apart like this. If you're not prepare yourself for a considerable fight!
The anti-roll bar links bolt through the radius arm.
The small end of the radius arm is bolted through the lower wishbone. First its necessary to undo the front shock absorber and move it out of the way. There is a special bolt that has a flat side so it can pass by the tube that holds the lower shock absorber mount. There is also a removable spacer to give enough room.
Here's the spacer still on the lower shock pin (the shock has been pushed out of the way behind).
Here's the bolt being removed once the spacer has been taken off and the pin knocked through to clear.
You'll notice that I have polybushes in the small radius arms and metalastic in the large ones.
At that point the radius arm is free.
