PHU41R Restoration - part 4 - now you see it, now you don't
iRS
Postby iRS » Sat Jul 23, 2016 8:48 am
This is the story of PHU41R continued from: http://www.jec.org.uk/forums/viewtopic.php?f=45&t=10454
The next job, and by far the most major to date, was to remove the engine. I think this was the end of January 2016. Until this date, the car still moved under its own steam, so this was a bit of a major event.
I removed all connections and many under bonnet parts ahead of time in preparation for the engine removal. This is by far the most complex car I have seriously worked on and I was removing some parts that I didn't even know what they were. I will, no doubt, find out when it comes to reassembly. Although awkward, most of the parts removed fairly easily. The exception to this was the passenger side exhaust down pipes which had been fitted with steel nuts. These took a very long time to remove!
I prepared the lifting chain some time ahead of time. I managed to buy suitably rated chain from the local hardware store! Watson's in Inverurie should anybody be interested. I then got hold of small shackles and a master link from eBay. The assembly was made as per the manual with four legs, the longer ones to the back. I borrowed an engine crane from a neighbour and carried out the job on my 4 poster ramp - with only just enough room to move.
The engine removal was pretty much as per the manual, but with a couple of learning points. I managed to get away without using the 'special tool' engine support that fits across the engine bay. I did so by supporting the gearbox from below when necessary. The other significant learning point was that although the lifting chain is of uneven leg design, this is only useful when the engine is part of the way out. I couldn't figure out why nothing was moving initially, until I lifted it all evenly and vertically to clear the steering rack and cross member. I did this by using the jacking beam of the four poster lift. Once clear, then it came out fairly easily, though I was pushed for space in front of the car. I had been advised to remove the steering rack, but found it was possible to ignore this advice, as long as it was cleared by the initial vertical lift.
The result:
There is another thread discussing the cylinder head removal and need for the service tool to prevent the liners moving with the heads off at: http://www.jec.org.uk/forums/viewtopic.php?f=41&t=10353
Roger S
Aberdeenshire
Early E
X350 - 2005 Super V8
1962 MGB
iRS
Re: PHU41R Restoration - part 4 - now you see it, now you do
Postby iRS » Sat Jul 23, 2016 9:58 am
Here's the engine just after removal. There's just not quite enough space between the front of the car and the wall.
The whole engine was very mucky and much time was subsequently spent cleaning off the muck. I mostly used Gunk to do this.
The other problem I had was that the engine was so big and heavy it was beyond the capability of my engine stand, so I stripped as many ancillaries off as possible to lighten it before I was happy putting it on the stand.
Roger S
Aberdeenshire
Early E
1962 MGB
iRS
Postby iRS » Sat Jul 23, 2016 10:07 am
Here's a picture on the stand with the engine mid cleaning.
Here's one with the V largely leaned up.
The distributor appeared to be in awful condition with some sort of Aluminium corrosion on going resulting in a powdery deposit.
Unbelievably the centrifugal advance wasn't actually seized and I have actually manged to clean it up and lubricate quite successfully.
Continued at: viewtopic.php?f=45&t=12285&p=66758#p66758
Roger S
Aberdeenshire
Early E
1962 MGB
Postby J44EAG » Sat Jul 23, 2016 11:10 am
That is a big old lump to heave around. Me hat off to you.
The white powdery corrosion is aluminum oxide and it is highly abrasive. ie aluminum oxide production paper can be obtained for flatting down objects. It is tough and aggressive as a preparation medium when used on suitable materials. On ali parts you will find Scotchbright pads very handy for removing heavy corrosion deposits. Avoid using wet and dry production paper on aluminum as it contains carbon and would be introduced to the micro structure of an aluminum part. This would react with the zinc content within the aluminum. Zinc and carbon together form the basis of a electrical primary cell "battery" and further corrosion would then occur.
Postby ptjs1 » Sat Jul 23, 2016 7:16 pm
Roger,
Great work and super pics! I know the v12 is "just" an engine, but it's an intimidating heavy old lump!
Well done.
poprivet
Postby poprivet » Sun Jul 24, 2016 6:58 am
British Leyland symbols on the heads, did those last until the HE heads or even later. I noticed one on the oil pump of my '88 so the ghosts of the past lingered on for many years.
