Precursors (that may or may not be relevant)
Since buying the car late last year I have driven maybe 200 miles without trouble, but not as crisply I I believe it should. Never-the-less it started on the button every time.
Last week I changed the ignition system to a new distributor with electronic ignition, new plug leads and new spark plugs. I also replaced the dud dynamo with a new alternator and dummy control box.
The car ran well for about 50 miles. This was a mixture of journeys so the car demonstrated both cold and hot running.
The Event
The car ran well for the first 500 yards from the pub (thus the chock was probably still operating). Without warning it cut out – dead! Attempts to restart produced no results, so we pushed it back to the pub car park. Further attempts to restart resulted in a few backfires, through the carburettor inlet side. The AA was called but could not identify the cause, so then they relay trailered us home. The AA confirmed that there was a good spark, that fuel was plentiful at the under bonnet fuel filter and that the choke solenoid was functioning.
Since then
Checked the ignition timing (with a strobe light, whilst the engine was turned over by the starter motor), proving that there is a spark and that it is sparking at the correct time.
I removed carburettors and gave a thorough clean and inspected for faults – none found.
Then I thought I had found the fault. There are two rubber pipes (behind and under the SU carburettors) connecting the feed from the choke carburettor to the inlet manifold. They were perished and cracked through (maybe they don’t last much more than 50 years).
I reassembled everything, set the slow running and mixture strength according to the handbook and tried starting the car. No improvement, only the occasional backfire, again through the inlet system.
In case I have reassembled something incorrectly I stripped the carbs down again, reassembled them and tried starting again. No joy. I have now exhausted my knowledge/skills and as for any help or advice someone out there can offer.
Phil
