codes
prsgue40
codes
Postby prsgue40 » Tue Feb 16, 2016 5:44 pm
Hi all. DSC fault again. S type 2001 vin M21457. MIL Display interminably showed DSC Fault. Would clear when ignition switched off. Went to local independent and had codes read. Only code they could recognise was C1279 (yaw rate sensor.) Said we will clear all codes. Did that now have the DSC light flashing at once per second all the time. Other codes cleared are as follows C1805,C1280 and 1963. Any one know what they refer to? Thanks Bernie
prsgue40
Re: codes
Postby prsgue40 » Tue Feb 16, 2016 6:34 pm
OK folks found a list of fault codes and a possible reason for the DSC light flashing. Under code 1279 and 1280 there is a note saying ' control module configuration using PDU is required when the fault is repaired and the DTC is cleared. The MIL will flash to indicate configuration is required.' Not sure what PDU is but will consult with a mate of a mate who was a jag techie. Will leave it a while to see if the original fault comes back. The link to fault codes can be found under General / DSC faults on page 3. As usual posted by Mike (J44EAG).thanks mike. Will report back. Bernie
Re: codes
Postby J44EAG » Tue Feb 16, 2016 8:20 pm
Suggest the good old battery "hard dump" method to attempt to rid the car of gremlins. It often works. Before disconnection, ensure you have your radio reset code to hand. The clock will also need to be reset.
The method is worth a try. It might avoid the PDU. I`m not sure what that is. Any one have an answer?
