S Type 2005 (55) Restricted performance
dennyboy
Postby dennyboy » Sun Nov 08, 2015 4:52 pm
Hi I have had a few problem with my DPF filter I have had it replaced with a new one under garage warranty but still had a red light come on with DPF full so took it to another garage who diagnosed the pipes were on the wrong way this has been sorted but now I have a restricted performance Amber light come on and the car won't go over 2500 revs so reduced speed does anyone have any idea how to sort this.
Thanks Dennis
Re: S Type 2005 (55) Restricted performance
Postby J44EAG » Sun Nov 08, 2015 7:52 pm
Possible turbo actuator valves?
back to the garage again. I think.
robv12
Postby robv12 » Mon Nov 09, 2015 10:39 am
agreed, a proper scan first , use someone with Autologic, Jaguar SDD, rather then a generic hand held cheaper style scanner, to get the best results
report back and we can go from there
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
dennyboy
Postby dennyboy » Tue Nov 10, 2015 6:20 pm
Thanks guys will drop it into garage tomorrow will let you know, can you tell me is there one or two actuators and where on the car are they.
Postby J44EAG » Tue Nov 10, 2015 7:09 pm
There are some poppet type valves on the engine which can deteriorate and cause vacuum to be lost and also there is a turbo actuator unit on each turbo charger which has been known to have problems.
Regret I`m not a diesel man so my knowledge is rather limited.
A trip to the garage should hopefully find your issue. Hope all goes well.
