Seemingly, not the pads, Paul. All other models listed. The SNG site also.
Gentlemen...please welcome the new J44EAG.
Re: Gentlemen...please welcome the new J44EAG.
The small pulley and oil kit together with special needle roller grease are now here. Total cost from Lawson at Powerhouse including VAT and post was £176. Snout bearings, a new drive coupling, the front oil seal and rear needle roller bearings are also available at extra cost. The large central rotor bearings are a more difficult issue if worn as the bearings are swagged into the centre plate of the charger. If those bearings are worn, then best advice is to look for a new supercharger....
Here is the link to Powerhouse.
https://www.google.co.uk/url?sa=t&rct=j ... 4247,d.ZGU
Lawson really knows his stuff. By training he is an ex RAF gas turbine engineer, so he should know a thing or two about compressing unburnt charge fuel and air. If you contact him you will find him a delight to deal with. No high pressure sales pitch and very happy to spend some time talking to you. He won`t rush you into making a purchase.
Powerhouse offer two small supercharger pulley alternatives. The larger of the two known as a 1.5lb pulley gives an extra 25hp at an increased boost pressure of 1.5psi. No modifications to the supercharger snout are required. The smaller pulley is known as a 2.5lb pulley gives an extra 35-40hp at an increased boost pressure of 2.5psi. However the snout of the charger must be carefully modified down to an O/D of 54mm. The reduction in O/D may be achieved with hand tools or better still by machining in a lathe.
The 2.5lb pulley I now have has a shaft I/D of 0.777"/19.28mm. The I/D of the pulley is 2.16"/54.75.. with the O/D of the driven pulley surface being 2.6"/66.2mm. The snout of the charger must be machined down to an O/D of 54mm to give a 0.75mm running clearance. Allowance must be made in that machining process to accommodate a 45 degree chamfer on the back edge of the pulley. Image here show replacement supercharger oil, a small container of special grease used to repack the rear rotor needle rollers and the 2.5lb pulley itself. I`m currently still waiting for Harwoods in Chichester to phone me before going over to collect what I hope will be the correct valley hose which will be replaced as preventative maintenance whilst the charger is off the car.
Many of you have advised I clean up the ground points on the front of the car. This is achieved by removing the plastic bonnet slam panel trim. I took a look/see today and the connections at that point are indeed rather grotty. The off side corrosion can be seen in centre of the next image. The near side connection point is in a similar condition. I`ll attend to those two issues tomorrow. Mike
Mike,
Front Brake Pads for XJR on Page 2 of the Brake Section of British Parts. Rear Pads on Page 3.
Looking forward to hearing about the power improvement with the revised pulley.
Judging by the photo, Mike, your earth points are nowhere near as bad as many! In fact, I'd say, they look pretty good compared to most! Really bad ones literally fall apart!
Strange how I missed the pads on the British Parts site. I must have been snow blind at the time I looked. Parts searching across sites can be very tedious especially if you are looking for the best price available.
Anyway, Neville came up with the pads. £94 in total including VAT and post. Fast delivery too.
The larger pads in this image are obviously the front ones. Over to Harwoods this afternoon to pick up the supercharger pipe which frequently fails at high mileage. As I will soon have the charger off for modification, this pipe will be changed as part of my preventative maintenance regime. This pipe is known as the single pipe arrangement and is suitable for supercharged cars up to 2005. The part number is C2C 18161. The cost was around £48 after JEC discount had been applied. ( Late edit. The hose and part number shown here is in fact NOT the hidden hose under the super charger. It is the one which connects to the inlet/outlet pipes on the inter-cooler bricks. The hidden pipe and its part number is presently unknown to me and I am making enquiries to find it. Seemingly not easily visible on parts listings)
it The boot mat arrived today rather tightly rolled in a cardboard box as predicted by Paul. This is a basic no frills mat which should give good protection. Paul suggested the mat would need to be left in the sun to flatten out. As the sun went away here today, I warmed the mat for ten minutes in front of an infra red heater. That made the mat much more pliable and the unit which had previously resembled a Network Rail stale cheese sandwich gradually revealed its true shape. The mat looks a bit naff and rather cheap out of the car but when flattened out with a section of anti-slip carpet moulded into the upper surface and placed within the car boot, it looks quite acceptable. The mat also fits the car quite nicely too. The cost was £31.36 including post from Germany. Here is the link to the product.
http://www.ebay.co.uk/itm/291357049847? ... 2749.l2649&
ssPageName=STRK%3AMEBIDX%3AIT Only the K&N filter and the future servicing kit now still awaited. It will soon be time to begin taking this car to pieces. I`ll document the supercharger rebuild process in a separate post.
Behold, the new K&N 33-2273 K&N filter has arrived. Washable and re-usable almost indefinitely, fitting one of these filters makes economic sense if you aim to keep a car for a few years. Just under £37 delivered with warranty. Cost compared to an OE filter is around £10 more but you never have to buy another filter again.
Advantages....increased airflow through intake system and improved acceleration and general engine response. I`ve had these filters for years. A good investment.
No more excuses left now. All parts here. Going out there to pull the supercharger off and fit the smaller pulley.
Dave and I have had a full day fitting the new small 2.5psi pulley. I`m rather black and tired tonight so this post is a little brief. I shall fully document the full procedure in another post under an appropriate heading. I think you may also see more about this job in the magazine at a later point in time and also something about the importance of HPI type checking before buying a used car. Nigel is quite keen I produce something on the matter.
Right. This 2.5 pulley change is NOT for the faint hearted or inexperienced home mechanic. The fitting of a 1.5psi pulley would be much easier. No machining of the supercharger snout is needed. However with the smaller 2.5 unit the amount of work required is much more and in my opinion only confident and experienced people should attempt this work. You really do need to know what you are doing!
Grinders, power files, flappy discs, vernier gauge equipment, blow torch etc have to be used unless the snout is removed from the supercharger and sent away for snout case reduction diameter by placing in a lathe. That was what Dave and I were aiming for this morning but our procedure did eventually have to rapidly alter as the job progressed.
The difficulties of snout removal are greatly exacerbated because the supercharger has to be removed from the car to allow it to be removed to a work bench. It IS quite impossible to get the snout off the charger without taking the charger off. There are two well buried bolts at the front and another at the back end. To get to the back bolt, the throttle body, hoses and I believe some dismantling in the area of the EGR valve. Apparently this job is not easy. It certainly looked difficult to Dave and I. It brought us to a halt for half an hour whilst we discussed pros and cons. So the plan changed.
We decided to attempt the less accurate but possibly the best answer to avoid all the above work. That entailed removing about 3mm of aluminium from around the snout diameter with hand tools. Having protected the car and as far as possible the engine and ancillary components with various cloth sheets, we proceeded to manually remove the aluminium from the snout. A power file is essential. Only with such a tool can you hope to remove metal from the lower part of the snout case. It is a long laborious, tedious and nasty job. We spent four hours removing that metal to achieve a running clearance for the new smaller pulley. Then we blended out abrupt changes of cross sectional area to produce a stress relieved blend of our work into the original remaining diameter of the snout. Very time consuming and accuracy remaining a prerequisite requirement.
Tonight we have the diameter machined down just right. The new pulley was heated to straw colour and then very rapidly transferred to the charger drive shaft to cool. The pulley effectively was sweated onto the shaft. The light went at 19.30 this evening so that was the end of the game for today. Tomorrow we put all the ancillary parts back on again and change the charger oil. Loads of pipes and spring clips. So far so good with just one vital retaining clip for the header tank having disappeared down below somewhere. This needs to be recovered.
Only three pics because of site loading limitations. Have asked James to try to get this sorted.
The old large pulley having been sectioned down to allow hoop tension to be relieved and the old pulley to be removed. Comparison of the old large pulley and the new stainless pulley. Note the very much reduced external O/D and internal I/D diameter of the new pulley which required the charger snout to be reworked to suit. The new pulley fitted. Note the straw colour due to off car heating with a gas blow torch and the evident reduction of snout O/D and the blending of the snout structure to allow a pulley running clearance. Worth noting that the back edge of the pulley has a 45 degree chamfer on the rear edge diameter. This helps clear the change of section at that point on the snout. This job has to be only for a real engineering enthusiast. Its a lot of hard work. I had to keep my mind on the prize doing this work. My target with this job is to get this engine producing 450 flywheel horse power with this mod in conjunction with a K7N 33-2273 air filter.
Looks like my brief post has become a long one! More tomorrow.
Mike,
Well done! Looking forward to seeing the results.
Sounds like the £265 labour that Powerhouse automotive charge to do the whole job would be money well spent for most people.
On a more mundane level compared with what you are doing, be careful if or when you try to remove the earthing nuts...er sorry grounding nuts as they can break easily due to unseen corrosion.
Splendid stuff Mike with excellent photos, when do you fit the twin turbos? That would give a lorra lorra power!
Don`t tempt me, Barry!
Fitting a Wizards of Nos kit would be a lot cheaper and quicker. About £900 with just a couple of fuel and NOS injectors inserted just upstream of the MAF sensor.
Easier still is to have the ECU remapped. Sadly this car has a Denso unit which currently cannot be reprogrammed via the OBD port. This apparently changed from MY55 plate cars on-wards.
No worries though because Racing Green can do it but I have to leave the car with them for a week. They are only in Guildford and about an hour distant. If I went in that direction with further tuning, the smaller pulley mod could be factored in to a remapped chip.
The RG mod is to remove the ECU from the car onto the bench. The existing program within the non write chip is copied to computer. The old chip is then taken from the ECU and set aside. The new chip is a read and write unit. This then receives the old program from the storage computer and the ECU put back in the car. Access is then possible via the OBD port. The car is put on the rolling road and new perimeters are installed by manually in-putting via computer in a similar way to normal chip tuning. The cost is £800 PLUS vodka and tonic. So it is about a £1060 jobby. Where there is a will, there is a way for the determined......with or without NOS or twin turbo units!
Some guys in the States have achieved 600bhp at the flywheel. I wonder how long those power units last?
Gaining power is one thing but reliability must be maintained as well as indeed drivability. One also has to consider that the M112 has limitation issues due to its early design. It becomes very inefficient at higher RPM and it is also necessary to uprate the inter-cooler system to keep unburned charge air as cool as possible. As it is, the design we have on standard cars is only just sufficient. Hard driving shows up that deficiency with loss of power when the inter-cooler system becomes over worked. There is no usable space in the engine bay of an X350 to install a larger charge air system. It is possible in a 308 but not in a 350. To get much more out of the M112, porting of the internal compression plate and the rather restrictive elbow is needed. Unless you are drag racing, the mods are not really beneficial. All this stuff goes hand in hand with the need for an uprated inter-cooler system. (Late edit. Not so!. August 2016 saw me remove the charger and port and polish the charger. Together with a sports cat conversion and an X-pipe, the car lifts itself to another level!!)
The M112 is a Fifth Generation unit and is stone age design compared to the later Sixth Generation which has six compressor blades instead of four. The new rotor blade design is awsome. As the rotors revolve they "twist" the air by 160 degrees and impart unheard of velocity to the charge air which really is forced into the engine. Then compression ratio of the pistons becomes a huge issue as extreme anti-detonation measures have to be employed. Modding one thing usually lads to others. There is only really so much that can be done with such old technology. Remember the basic design goes back to about 1996. Time and technology move quickly.
I only got up to deal with a leg cramp and now I`ve had to deal with this query. Perhaps I can go back to bed again.
Wow, that's a really great write up !, nice job !
Now I wish I had gone supercharged when I got the XK8
XK8 MY2002
£265 spent at Powerhouse to modify the snout is about as good as you will get. Initially the worst part of the job is getting all the hoses and clips released. The hoses stick badly to both ali and plastic components. Then the old pulley has to be cut away which is quite nerve wracking for the first time. Powerhouse obviously have this down to a fine art and have developed a machine which will reduce the snout diameter very quickly and easily. So properly kitted out and having done the job many times, they will be a lot faster than Dave and I were yesterday.
On the basis of machining the snout in situe, Dave and I removed more components than was strictly necessary, ie the expansion plenum feeding charge air to the throttle body and the underlying manifold which exits the charger and feeds the compressed charge air to the intercooler bricks. We did this strip down because at that point we were about to remove the whole supercharger. Then matters changed and we decided to machine the snout whilst still on the car.
Having fitted the small pulley we then had to refit all the gubbins. Loads of pipery and clips etc. We were able to clean the throttle body throat with rag and carb cleaner to leave it free of crank case breather gunge. As Paul has previously stated, Jaguar literature says the throat can`t be cleaned and that the PTFE coating would be destroyed. This is total rubbish. I`ve been cleaning throttle throats using soft rag and cleaner for years and have never damaged the hard wearing coating on the throat of the throttle body. I fail to understand why cleaning should not be attempted or be totally successful on Jaguar vehicles. I think someone is neatly distributing bull dust in the hope of being able to sell a new throttle body at around £1500 each from the Dealer network. If a throttle is dirty and according to Jaguar must be replaced, then cleaning will loose you nothing at that point. I have previously cleaned my throttle bodies every 10k miles with no adverse affect except on my pocket which appears to refill with cash each and every time I clean the throttle up. So my X350R has been given this treatment with no ill effects. Here is one I cleaned earlier! What can possibly be detrimental in simply removing black oil from a throttle bore and throttle plate. Come on Jaguar. Pull the other one!! Lets act like knowledgeable engineers who are able to think for themselves. Here is the 350R throttle body mounted at the back of the supercharger and tightly squeezed under the front lip of the scuttle panel. Pre-cleaning the ring of black crank case breather residue is just visible as a black ring of filth above the throttle plate. To clean above and below the plate, the plate can be moved against spring pressure and a soft rag and carb cleaner used to remove the oily build up. A smoother idle will result as more air can be fed to the engine with the black mess removed. The black rubber pipe to the right of the throttle body is the outlet from the supercharger. a plenum unit fits into the pipe and then distributes charge air via the intercooler bricks into the engine. We moved onto changing the supercharger oil. On the front face there is a threaded screw in bung removed with a hex Allen key. It is fitted mighty tight. Removal of the bung allows old oil to be sucked out and refilled with new. A small sample of oil taken showed it to be in good clean yellow coloured condition with no break down apparent. The last oil change I did on a 300R had the oil come out like grey gravey. We changed that with a small pipe and a syringe. Refill is the reverse until oil just comes out of the bung.
With that done we built up the front end of the engine again, Dave having recovered the spring clip which went flyabout when the header tank bottom pipe connector was removed yesterday. New antifreeze was added to the header tank, the car warmed to full operating temperature and air burped from the header tank and by releasing a high level pipe from one of the intercooler bricks. There is a 17mm hex screw bung fitted at that pint but we didn`t have a large enough Allen key to allow us to fill and burp at that point. So we pumped hoses and released pipes until the coolant system was hot and evacuation of air was complete.
Here is a general shot of the basic guts of the supercharger installation. I`ve had to rotate the shot to make it fit the 1300x900 requirement of the site. Visible on the left is the throttle body throat, in the centre the supercharger, and to the right, the long snout and the new fitted pulley. One not unexpected issue still needs to be resolved. The notorious header tank sub pipes frequently break due to prolonged heat exposure causing the polypropylene tank material to embrittle and the small pipe diameter which is unreinforced and is liable to snap when old age sets in. Indeed we noted that the smaller of the two pipes on the tank was rather short in length when we refitted the tank. Inside the rubber pipe which joins the tank pipe, we found a 10mm long section of the header tank pipe.The damage had previously been done. Fortunately there is enough pipe still available for short term use but this tank now needs complete replacement or some other modification applied to address the issue. To have to replace the whole tank is annoying as the remaining 99.999% of it is in perfectly usable condition. My advice if replacing is to fit a NEW tank rather than fit second hand unless the tank is known to be very new.
With everything back together and coolant burping complete we took the car for a short run around town. What is it like with the pulley mod and a new 33-2273 K&N filter fitted? Certainly an impressive improvement with a noticeably quicker throttle response and less supercharger lag than previously. Rather more spritely....not that it was a slouch in standard car trim. I`ve not driven the car far yet having spent the afternoon getting cleaned up and putting tools away. Worth the £148 cost of the pulley? A definite yes but full effects yet to be explored.
I`m now totally exhausted from standing on my sciatic nerve affected right foot and need some well earned rest. I`ll hack over to Halfords to get some more antifreeze tomorrow so will be able to open up a bit and ascertain the full effect of the work done.
Well done Mike!
Have a rest this evening and enjoy the rugby!
That header pipe small stub is an annoying design. I know one owner who had the same problem as you, with a part of the pipe broken in the hose. He used a very thin metal sleeve inside the broken stub as an an interference fit and clamped it back up. When mine broke, I decided that a sleeve was not a practical idea and replaced the header tank. I suspect most owners do this.
I wasn't aware that Jaguar said not to clean the butterfly throat or that it was because it apparently destroyed the PTFE coating. My comment was that the respected XJK told me not to clean it (unfortunately after I'd done it!) as it can cause an air leak if "too clean". I certainly experienced high idle on startup for some months afterwards. If you do clean the throat, apparently there is often a need to reset the idle position by "reteaching" the ecu where full throttle and idle throttle should be. As I said, mine took 3 months to finally settle down.
I know you wanted to get the job done quickly but I would love to have seen you do timed acceleration comparisons pre- and post-installation. As with any enhancement, we all want to know the real benefits of such work. It's the reason I've held fire from fitting the ignition advance bracket on my XJS so that I can document the before and after accurately. Anyway, I'm sure your R will perform great even before a re-chip! I somehow think this car is going to end up looking like a 350 version of the old J44!
Have a beer!
Have a beer!
The tank is C2C41300 and is specifically for 350R, STR and XFR models. It also has at least another six other cross reference part numbers to contend with. Early indications are that the cheapest price I can find after a brief search is from David Manners at £96.38 with VAT and post. However, I`ll have a word with our Neville and see what he can come up with.
The throttle plate must snap shut with an audible "pop". This must occur from full throttle and at just off idle positions. I`ve had these spindles and plates so gunged up that the sound is muffled and the action more akin to a ratchet. Really good cleaning of the throat, the throttle plate circumferential edges and where the spinal passes into the body of the unit must be clean as a whistle...seriously clean. Removal of the unit from the car is the quickest and easiest method of ensuring the throttle is like a new pin internally.
I`ve seen the throttle plate stick up and not close fully if the slightest trace of hard carbonised muck is present. The whole unit is a precision unit. The fact that your unit, Paul, later improved its idle may have been because some gunk may have been left on some area of the body or plate and this might have held the plate off closing fully and which later unstuck itself. The adjustable position sensor (TPS) may also have previously been moved or a hard spot developed on the internal track within it. I`ve ditched a couple of TPS units when I have serviced a throttle body. When I clean these units, I let carb cleaner soften the muck for a few minutes. This makes cleaning considerable easier as the cleaner starts to dissolve contaminates and it then all cleans up without much effort. I clean the parts with masses of carb cleaner at least three times before I am satisfied, paying particular attention to throttle plate edges and the throttle spindle and seals.
To date I`ve never had elevated idle speed issues after cleaning or indeed removing or changing the TPS. On the S-type, I`ve occasionally removed the air assist valve from the inlet manifold and cleaned that in a similar manner. Internally it is a ported sliding sprung loaded piston arrangement which must move easily to ensure the correct amount of air is available to the air shroud that surrounds the injector nozzles. Dodgy air assist causes poor fuel atomisation and occasionally a rough idle. I have a small pile of S-type V8 throttle bodies which I have collected over the years. Six rough ones became four good ones! All tested on my S-type and all fully working without fault. Now I have the 350 these are surplus to my needs. If anyone wants one for a small stipend, please PM me!
A bit more now to report on how the R is now performing with the new pulley. I`ve found the traction control a bit sensitive generally when trying to enter the roundabout just up the road. Once has to be able to get on the throttle quickly when traffic is heavy on the A32. This is because traffic entering the roundabout from my right does not like slowing down and letting people in from the side turnings. The DSC can be most annoying in such situations as it will hold back the throttle response and stop you making a quick entry. So I`ve taken to switching the facility off around town. Before the mod I found the car had quite a slow pick up. Now that apparent flat spot has gone completely but switching the DSC off is now even more prevalent with rather more grunt available. Overall pick up is much better and the car accelerates with far less effort. Given a fair bootful of throttle the car gets going quicker and the increase of torque is useful and noticeable at low throttle openings. The car feels much more responsive and opened up is markedly quicker through the gears. The supercharger whine develops at lower throttle openings. To make the car move well you need to get the supercharger wound up a bit and with the pulley mod done, that whine develops lower down the rev range. That much is clearly noticeable.
This 350 will visually remain a Q car. However what occurs within might just receive a few useful but discrete tweeks. To max this lovely R out like the S-type would be to spoil it. The S-type was built for a purpose. In the past my business and personal life moved at a much faster pace than it does now. I needed a rapid car to get me where I wanted to be pronto and without bad road manners. The car had to handle and have the grunt to match. It was worked hard for a living and has done what I intended extremely well for nearly ten years. The 350R I promise you will lead a much less demanding existence. Two different cars built from a similar design idea but both achieving in a very different ways. The S-type is the angry around town sprinter with hooligan handling whilst the R is an understated long distance mile cruncher with a hidden sting under its dinner suite exterior.
I`ve not yet had the car on the open road but confidently expect a very noticeable change to be apparent. Its not so much what it does but more importantly it is the way in which it does it that makes for an improved driving experience. More soon.
Please do not mention the rugby. To add insult to injury I have to drive to b......y Wayals past all the gloating boyos to the Western day tomorrow! I just hope I am not approached by anybody with a vaguely Welsh accent saying how good the match was.
Oh sod it , ok lads we let you win on purpose.
i]
Forget the rugby. The ball is not even a good shape.....nor is my super dooper pulley drive belt any more!
A boot full of throttle this morning had the original 78k mile belt which was looking a bit worn on the ribs off the pulley. Instant lack of supercharged performance! Pleased to say that the belt only drives the supercharger and not the water pump, alternator or other prime services. It is possible that a surface coating of antifreeze may well also have been a contributory factor in the car chucking the drive belt off. Given the mileage it might also have stretched slightly in length with the small pulley not helping the situation and possibly further reducing belt tension. Poo happens and the development work goes on.
Interesting that the car still runs well without the charger in the circuit. So the car effectively becomes a high compression (11:1 CR which is pretty high for a force fed engine) naturally aspirated power unit until the drive belt is replaced.
The last serpentine belt I replaced on J44 was at 80k miles. It was a tad longer in length than the replacement. So it is worth noting that these belts do stretch after prolonged service and this XJR was fitted with an aged belt. Replacement was bound to have been needed in the near future. I just got there a bit earlier than anticipated.
I`ve ordered a new Drayco belt from ebay for £26 or thereabouts including first class post. The seller is in Feltham in London so it shouldn`t take too long to get the belt down here to Fareham on the South Coast. Even with the belt off the pulley, the car can still be driven and retains similar performance to a naturally aspirated 4.2 X350.
The belt is C2C37055 and fits MY02-09 cars. It is also suitable for XFR and STR supercharged vehicles. Here is the link.
http://www.ebay.co.uk/itm/DAYCO-SUPERCH ... 2a3eb37fd7
So off with the induction pipe yet again with probably header tank and top left hose having to come off as well. The pulley tensioner is located low down under the tank with a half inch square drive aperture into which a torque wrench square peg can be inserted. The tensioner tension can be induced by levering the wrench from left to right only letting the wrench then move back to the left when the new belt has been fitted. Its all a bit of a fiddle with little space available in which to work.
Looks like I`m at the helm of the S-type again for a couple of days. One has to expect a few issues when working at the cutting edge of supercharger development work. All part of the fun!
