Auto Transmission replacement
dg4cars
Postby dg4cars » Sun Jun 28, 2015 12:11 am
Well, after 174 k miles the gearbox failed. The car was one owner when I bought it with 100k miles. Yes we followed Bob Bates advice regarding regular transmission oil changes. The gearbox was replaced with a similar one of lower mileage. Hopefully we are fit for another while. Interesting the gearbox warning fault continues to appear on the dashboard. It extinguishes when engine turned off . Any ideas please??
Re: Auto Transmission replacement
Postby J44EAG » Sun Jun 28, 2015 12:55 am
Try a 20 minute battery disconnect in an attempt to clear any remaining fault codes.
If the lamp still illuminates after disconnection and reconnection, then there would appear to be a fault still present.
A scan would be the best form of action. Cheap code readers are available easily via the internet. The more you pay, then the more you can interrogate.
174K miles is an incredible mileage for an early model 5R55N gearbox. You certainly had your monies worth from that unit. I do not think that gearbox would have lasted to that mileage had you not had the oil changed. About 130K is about the norm for a 5R55N. Often it can be considerably less. My original gearbox lasted just 54K miles.
The golden rule with replacement gearboxes is if fitting a reconditioned unit, to have the torque converter cut open, cleaned out and rewelded and balanced before pressing a refurbished or other gearbox into action. The oil cooler and pipes may also need reconditioning. Newly refurbished gearboxes fitted to used converters and coolers which have not been cleaned out are unlikely to enjoy a long life. Particulate from a used converter or oil cooler will quickly act as an abrasive on the internal parts of any newly fitted gearbox.
Sorry I`m not more encouraging.
dg4cars
Postby dg4cars » Tue Jun 30, 2015 12:09 am
Thanks Mike,
Every bit of info helps
Best Regards,
Derek
dg4cars
Postby dg4cars » Fri Jul 10, 2015 2:06 pm
Transmission replacement update.
Delighted with work done by my garage , they replaced the gearbox.
Over the last week I drove the car from SW Ireland to Norwich via Wales and Peak district and home again.
Looks like Ruby ( my Stype ) will survive for a few more years !!
Next project will be to sort out the aircon, it was 32 C in Esat Anglia last weekend, thankfully Ruby has a sunroof ...... :D :D :D
dg4cars
Postby dg4cars » Fri Sep 04, 2015 10:14 pm
Delighted to report that the replacement gearbox is going well. Looking forward to our JEC tour of West Cork this weekend :D
