Mission creep has set in again!
What started of as a general fettling with a few jobs and an MOT has turned into another marathon, there goes the boat budget!
Variously the state of the old fuel tank, badly corroded and stinking the car out, shocking state of the radius arm bushes which were only fitted last year and done a few thousand miles at most. Fitted new DB7 springs and shocks last year but apparently the collets were fitted the wrong way round putting the alignment out by about 10mm resulting in split bushes; now replaced with Aston units and Vee mounts.
Genuine TWR back boxes with twin pipes, more dreaded rust but not a huge amount thankfully.
Also done are the diff seal, gearbox seal and spring mount, very expensive oil change, drop link bushes replaced, steering rack leak fixed, entire fuel pipe replaced from tank to engine, front brakes and ABS sorted, thermostats and rotor arm replaced along with throttle actuator arms and bushes.
I need a lie down in a darkened room now.
David at Alders Classics reports that the car is running really well and sounds great; unfortunately I can't get it back until the week after next but I'll report back then.
Annual work up
Re: Annual work up
Do you know where your fuel lines were sourced from - mine will need replacing soon and have not been able to find original parts anywhere?
Re: Annual work up
I think that he just got a length of copper fuel line and made it up from scratch.
Re: Annual work up
Nice cat
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
Re: Annual work up
I reckon so but I don't get to drive it that much!
Re: Annual work up
Well, the car is nearly done. Flew through its MOT last week with the tester saying what great condition it was in and then later wouldn't start!
Turns out that one of the crank sensors was breaking down so getting them both changed and hopefully it will be fine.
Should get it back next week and can't wait to hear what it sounds like; centre boxes removed and TWR twin tail pipes.
Re: Annual work up
sounds like your getting a little excited......and why not
the sound is quite different and quite sporty ,
at idle she will ' burble '
at low revs she will ' warble '
and a full chat she will ' growl '
and i think you may like it , lol
do you know which sensor was breaking down , or do you think it was just a gap distance issue ? as they need to be within 2 thou , no matter what the book says....
Re: Annual work up
David said that it was the front one but he is going to change them both to be on the safe side; I guess that they will be of a similar age and if one is going pear shaped then the other probably won't be far behind.
Re: Annual work up
Always a good idea to change suspension parts in matched pairs. Did the same myself when I replaced all bushes in sets recently when I completely ripped out and rebuilt my S-type suspension.
Once you change some components they tend to show up other aged parts. One thing often leads to another!
Re: Annual work up
So true but sometimes cost can be a factor; as I said at the start, mission creep has totally set in again!
Re: Annual work up
Well, the beast has returned.
Unfortunately I am stuck away at work until the 14th so can't even look at it let alone drive it.
Bummer!
Bummer!
