Hi from Yorkshire
National2188
Hi from Yorkshire
Postby National2188 » Thu Apr 09, 2015 7:19 pm
Evening All,
After two X-Types, I've recently bought an 04 S-Type 3.0SE in JRG and with the High Luxury option, to use as a personal 'weekend car' after each working week spent in my company car.
The car has 72,000 miles on the clock, with a good service history. I'm just doing small jobs to get the car up to standard , as it will be due it's annual service in May and I want to give my local independent garage a list of jobs that I've found, although I've done several myself. I'm going to get them to do a full service (including plugs) so that I have a baseline to work from. I also want them to change the oil in the auto box, again as a baseline for my ownership.
It's quiet, smooth and powerful - a real joy to drive. (My wife even approves, which is a bonus!).
Are there any other points I need to look at / watch out for?
In due course ( after the service) I'll ask for advice about alloy wheels / tyre sizes, as the ones fitted are a little scabby and I have some 'old' X-Type ones in the garage.
Safe travels everyone.
2005 XK8 4.2 Convertible in Platinum Silver
(Previous owner of four X-Type 2.2D Manual Sovereign Estates, one an 06 plate; one on a 57 plate; one on a 58 plate and one on an 09 plate, an also an S-Type 3.0SE in JRG with an Ivory Hi-Lux pack)
Re: Hi from Yorkshire
Postby J44EAG » Thu Apr 09, 2015 10:08 pm
Welcome.
Check out the gearbox section on this BB and go for a full gearbox flush at an independent gearbox specialist. This will need doing if not already done. This item is NOT in the Jaguar servicing schedules as it was not thought necessary. Believe us all on this site when we say it needs doing at 72K miles. Expect to pay around 3400 for this work as the six speed cars have the filter integral with the gearbox sump. The oil is expensive and MUST be the correct spec. Do not use Dextron or other types in this gearbox. Manufacturers spec only..
Also check out the overview section on this site for my hints and tips guide for owning and running an S-type. Ask any questions of us as you wish. Happy to help.
Time spent perusing the sections on this BB will help you to understand the car and deal with any issues you may encounter.
Hope that helps as a starter.
National2188
Postby National2188 » Thu Apr 09, 2015 10:50 pm
Thanks, Mike.
I shall definitely get that looked at when it goes in during May. I'll check the BB as you suggest.
Bye for now
Phil
oldtimer
Postby oldtimer » Thu Apr 09, 2015 11:13 pm
Phil,
Welcome to the S type mob. Essential you do as Mike says re the G / Box.
I do believe Mike means £300 to £400 for that job not £3400 don't want to frighten you off just yet, we'll save that for later. Not familiar with the in and outs of the Auto box as mine is a manual but from what I have read on the S type Bulletin Board it is imperative to chose an experienced specialist to undertake this task.
Pleased to see you have bought a Post 2002.5 year model cos that has all the good bits embodied.
Read all about it on our S type Bulletin Board
Happy motoring
Oldtimer
Montana5
Postby Montana5 » Fri Apr 10, 2015 1:55 am
Hi Phil and welcome.
Doug.
S Type Forum Moderator
National2188
Postby National2188 » Fri Apr 10, 2015 7:37 am
Hi Oldtimer / Doug,
Thanks for the welcomes and the correction to the 3400 - I hoped it was 340, but I wasn't sure if Mike was telling me that 3400 would be the cost of ignoring the gearbox oil changes and having to put a new one in!
I use West Riding Independent in Mirfield, West Yorkshire, and I shall certainly discuss the gearbox with them, as part of the cars annual service in May. They always looked after my X-Types very well and I trust them and their advice. They are ZF Gearbox specialists, so I'll keep my fingers crossed.
I am on the 'wait' list for the Jaguar Day at Coventry in late June (I think), so I may get to meet some fellow S-Type owners then. If any other S-Type meetings are planned, I'd be interested. I'm a member of the Yorkshire South JEC Group.
If any 'local' owners fancy a day out, the Carding Shed at Jackson Bridge (near Holmfirth) have the Oil Can Cafe and arrange some good events. Their season opener (a Spring BBQ) is on in May (the 9th, I think) but please check the website.
Kind regards
Phil
Postby J44EAG » Fri Apr 10, 2015 11:28 pm
Sorry about my typo on typical prices for full flush gearbox oil changes at an independent gearbox specialist. About £380 is the typical price down here in Portsmouth.
The sump/filter on a six speed ZF box accounts for about £175 and the special synthetic oil from Jaguar can cost around £25 per litre. Similar speced oils can be sourced from other manufacturers for rather more reasonable prices.
Gear box oil changing at an early mileage is definitely the way to keep a gearbox functioning for as long as possible to avoid failure. Running for a prolonged period without so doing is guaranteed to shorten the service life. So a few hundred pounds is well worth spending.
GordonJ
Postby GordonJ » Sat Apr 11, 2015 3:43 pm
Hi Phil,
good to see you on here. Mike's posts on here are better than any manual. His suspension posts are a good read and helpful for preventative maintenance.
Gordon
XJ6 X350 Sovereign
Previous Jaguars.
XJ8 Sovereign in Seafrost
S Type in Red
