Serpentine Belt
jonjeffryes
Serpentine Belt
Postby jonjeffryes » Sun Feb 22, 2015 7:50 pm
Not much time for fettling at the moment due to work demands and a sulking XF, but this morning I found an hour or so to replace the Serpentine belt which had clearly been on the car for many years.
I ordered a replacement belt from a reputable supplier which arrived on Friday. I knew the tensioner was in good order (checked it when I had to emergency replace the water-pump).
Quickly removing the radiator cover panel and air intake trunking allows access to the tensioner and belt, which was removed in about 5 minutes. Unfortunately checking the old belt against the new one showed the old belt to be about 30% longer than the supplied replacement!
So the old belt was thrown back on for now - it will need changing urgently - and a new correct sized belt will be sourced. Annoying as I supplied full details of the car when ordering the belt, but there are certainly at least two belt lengths available for the 3ltr.....it would pay to check that you are supplied the correct belt before wielding the spanners - lesson learnt!
Re: Serpentine Belt
Postby J44EAG » Sun Feb 22, 2015 9:07 pm
Frustrating indeed, Jon.
I fear replacement sub=frame mounts might also be a similar nightmare!
jonjeffryes
Re: Serpentine Belt
Postby jonjeffryes » Sun Feb 22, 2015 10:57 pm
Mike,
That's something I look forward to....not a lot!
