Headlight relay?
Moderator:LJR
CliveRothwell
Headlight relay?
Postby CliveRothwell » Mon Jun 02, 2014 10:47 pm
series 3 xj6 1985 car
Trying to sort none - functioning inner main headights. I THINK the wiring is OK. - blue and white for power, black to earth. Pulling the L/H stalk doesn't get the relay to click. Does any body have a clue on how to test the relay (other than substitution)? Fuses OK
They did work a while ago prior to removal of the bonnet for a new one and the chance to re-new the inner bowls and dodgy wiring seemed like a good idea.
For what it's worth, the O/S outer bulb does not go onto main beam either................
PaulGover
Re: Headlight relay?
Postby PaulGover » Tue Jun 03, 2014 10:20 am
I've taken the headlight relay apart in the past. You need a thin-bladed screwdriver to flex the cover over the small retaining lugs on the base. As far as I recall (it was years ago) the mechanism is pretty primitive and it's surprising how long the thing works without problems! A bit of contact cleaning and greasing the pivot sorted my problem.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
CliveRothwell
Postby CliveRothwell » Tue Jun 03, 2014 10:29 pm
That's a good tip Paul - I'll give it a shot. I assumed they were sealed units.............thanks!
almcl
Postby almcl » Wed Jun 04, 2014 7:42 am
Clive
There's quite a good description and pics of refurbing the headlight relay here:
http://www.jag-lovers.org/v.htm?1080778679
Al McL
CliveRothwell
Postby CliveRothwell » Wed Jun 04, 2014 10:18 pm
Excellent Al! Many thanks - can you stop it from raining as well?
CliveRothwell
Postby CliveRothwell » Mon Jun 09, 2014 8:23 pm
A really good web link Al, thanks. 4 days later, every connection cleaned, full continuity, 12v where it needs to be, Relay OK, 4 main beam lights but still no dip. Just booked it into an auto electrician - I'd sooner be driving it rather than messing with it any further! (This is partly why I put it into storage and bought the XJS which IS brilliant day in day out!)
CliveRothwell
Postby CliveRothwell » Thu Jun 12, 2014 10:41 pm
Yup - dodgy relay plus a burnt wire and enough tidying to make it a bill of £200 once they had added VAT
Still, I'll be able to see it rusting in the dark now!
