Metric versus UNF and my nightmare day
Postby Brakebuster » Thu May 29, 2014 8:27 pm
so. i'm replacing some worn components on one of our fellow members car, this involves new stub axles and lower hub carrier ball joints on the front suspension , although a fairly straight forward process, the size and tightness of some of the nuts and bolts means a lot of knuckle bashing and sweating.......... :?
this leads me onto the problem ,
the lower ball joint seal had failed, letting the weather into the joint, this then resulted in a nasty squeal when turning the steering wheel , on a 1990 car i would expect its on its second or maybe third ball joint from regular service intervals .
with a high quality ( non Jaguar ) lower ball joint ready to be fitted , i tried the original nut as they dont come with the balljoint, hmm , doesn't fit , i hadn't bashed or heated it up , so shouldn't be a problem , tried again , hmm , went to my storage bins, and hour later with all the nuts and bolts spread on the floor i still can't find one that fitted , the original nut did start but soon bound up , so i compared the ball joint thread to the old one, looks the same, a fine thread , must be UNF , but what size ?
the original nut was defiantly a metric nut as it had a blue nylock insert , ( UNF have white inserts ) and must have been forced on by the previous ' ahem' mechanic :roll: stripping the threads
i pulled my garage to bits trying to find one...but no luck , i had UNF but not big enough..........got on the phone to the father in law and he told me about Allcap , so i jumped in my company car and went to get some
turned out i needed 9/16 UNF , span on like it grew there , go figure........
at 30p each they weren't expensive , but the right part is worth its weight in gold when needed ,
so a three hour delay to tighten one nut up ,
so what am i trying to say ?
well, the last person to fit the ball joint bodged the job for the sake of 30p , causing me a huge issue
but at least its got the right parts now,
just got to do the other side now
BB :mrgreen:
GordonJ
Re: Metric versus UNF and my nightmare day
Postby GordonJ » Thu May 29, 2014 8:33 pm
You have to ask yourself, didn't the person notice that this nut was not fitting properly. I have seen this before and on asking I found that the so called mechanic or fitter had used a huge wrench and couldn't feel that some thing was wrong.
PS. JRT just through MOT yesterday with no problems. :D
XJ6 X350 Sovereign
Previous Jaguars.
XJ8 Sovereign in Seafrost
S Type in Red
Postby Brakebuster » Thu May 29, 2014 8:40 pm
that is great news indeed :mrgreen:
i still miss her loads.............
dhdove
Postby dhdove » Sun Jun 01, 2014 3:00 pm
Vince
I sympathise, I deal with BA and Whitworth as well as UNF UNC and metric......
...it's a minefield!
TonyS
XJS Bulletin Board Moderator
almcl
Postby almcl » Sun Jun 01, 2014 4:19 pm
The metric/unf confusion nearly did for a colleague of mine a few years ago.
Tony may well remember this, www.en.wikipedia.org/wiki/British_Airways_Flight_5390
But the root cause was metric bolts inserted into unf captive nuts...
Al McL
