SNG sell polyprop replacement ARB bushes, Brian, for a similar amount to the standard squashy type.
Also to be found on ebay. Well worth fitting as they should last longer and fitting the off side front unit is a job you don`t want to have to do frequently. Access around the air con compressor is not easy. Fit bushes with ARB to anti roll bar links disconnected from the lower front wishbones. So much easier without roll bar tension working against you.
Early 4 ltr engine with 'ticking' timing chains!!!!
