Diesel injector sleeve clean up tool. Leak free injectors.
Postby J44EAG » Mon Apr 28, 2014 7:14 pm
Those of use who have occasion to work on diesel engines will be aware of this frequent issue.
I`ve lost count of the times I`ve rebuilt diesel engines and struggled having removed diesel injector from a cylinder head only to find that despite cleaning up injector and copper seal sleeve faces, the wretched injectors "chuff" slightly once an overhauled engine is started. Combustion gases leak past the injector sleeve and injector on the compression stroke and fuel leakage can also be a nuisance. The problem is usually that the copper sleeve seal in the head becomes marked or distorted causing an injector not to seat and therefore seal correctly. An excess of old difficult to remove carbon combustion by-product can also be encountered.
"Chuffing" injectors are a pain. Having built up a diesel fuel system once, it then has to be broken down to cure the issue and then built back up again. With this kit now in stock, I can ream sleeve seats before installing injectors at rebuild stage and do not have to take the risk that my work will be spoiled by leaky injectors.
I`ve promised myself a sleeve reaming kit for years. Now thanks to ebay and the Chinese tool revolution I have one for £23 delivered. The kit comprises a T-bar, a common reamer mandrel with dummy injector nozzle guide, five common sized reamer heads and an Allen key used to fit a reamer to the mandrel. Years ago and before the internet and ebay made cheap tools easily accessible, one would ether have had to have the sleeves professionally attended to or one hired a tool or paid and arm and a leg for an expensive trade tool. For us we are definitely on a winner when it comes to the current way we can buy what we need at affordable prices.
To use, one selects the appropriate reamer, fits it to the mandrel and places a little grease on the cutter head. The cutter is lowered into the injector sleeve and the T-bar is turned to remove copper from the sleeve base. The copper cutting swarf is held by the grease to ensure that it is removed from the sleeve and does not find its way down into the combustion chamber. The secret is to only remove as much copper as is required to produce a decent flat unmarked surface. A rag and screw driver are carefully used to remove any remaining detritus before an injector is refitted to the cylinder head. Carried out carefully, one should end up with a leak free injector.
What is next on my wish list? Possibly a broken spark plug removal tool and a taper seat spark plug renovation tool. Useful for petrol engines.
Re: Diesel injector sleeve clean up tool. Leak free injector
Postby Brakebuster » Mon Apr 28, 2014 7:24 pm
well Mike , all very nice ,
but I'm looking at a four post lift in the garage, lol
but need to put a few courses of blocks onto the existing walls for clearance ,
and you can get em on ebay , lmfao
BB :wink:
ps, i finally have a worthy rival for all my shiny tool sets , lol :mrgreen:
Postby J44EAG » Mon Apr 28, 2014 7:36 pm
Here you go, Vince.
http://www.ebay.co.uk/itm/4-post-ramp-C ... 1426881375
Only four days to go with only on bid so far of just over £25!
Would look good outside bristol HQ.
Postby J44EAG » Thu May 01, 2014 4:58 pm
Just had the injectors out of a recently rebuilt engine that had one chuffing injector.
Selected the right sized cutter, coated it in white grease and began reaming. Having cut through the carbon layer I immediately hit the surface of the copper injector sleeve. The feel of the tool cutting action changes and one can feel the copper seat being reamed. A few more gentle turns of the tool left the face nice smooth virgin copper. Repeated on the other seat, popped the injectors back in, linked up the spill return pipe, bled off the air on the feeds, carefully tightened the tie down clamps and the engine started first turn of the key.
What joy. Not leaking fuel or combustion gas, smoother running and a perfect result. Well pleased.
The above injector seat cutter worked a treat. A cracking little tool seat for not much money. Highly recommended.
Postby Brakebuster » Thu May 01, 2014 5:05 pm
:mrgreen:
oldtimer
Postby oldtimer » Thu May 01, 2014 6:27 pm
What Oh Mike,
Your new cutter sounds the business. You are so right about tool costs. Years ago I would gaze at new tools and have to walk away knowing the kids new shoes were more important. (Well, according to her indoors)
BB. A four post lift is a great idea. I obtained mine about fifteen years ago for £50 .00. It was to be chopped up with a gas axe so got it out quick before anybody changed their minds. I did have to replace the three phase motor with a single phase one along with a reduced sized oil pump - that was a bit costly. Like you will have to do, a bricky raised the walls and I built a pitched roof under tiles. Whilst I was at it I put in two RSJ with a 3 ton block and tackle in line for lifting a V12 engine. I did all that when I was sixty, but now the mind is willing but the body is slowing down. Without the lift I'm not sure that I could "scrabble" under motors any more. My old XJ lives upstairs and the S type is parked beneath.
I think it is a great idea - every house should have one - If I can help in any (as long as it's not money) you know where I am.
Oldtimer
PS I thought your G/Box job was great
Martec
Postby Martec » Thu May 01, 2014 8:23 pm
Hi Mike,
At sea we were required by insurance to carry a full change of injectors, which were pop tested and pressure set just prior to an set of injectors to be changed, then everyone set to and we pulled the old ones, cleaned the hole and fitted the replacement. Having had injectors seize in before now and had to use wedges to try to remove them before head off and smack them from the inside, I always coated the barrel of the injector with copperslip. That way if there was blow-by it would not seize it in again.
These were biggish injectors, about 12-15" long and very heavy for a weakling like me, A set was 9 to 16 depending if it was a straight 9 or V16, with usually 2 blowers they sounded fantastic at full load.
I have a habit of using copperslip on most things mechanical!!??
jeff1954
Postby jeff1954 » Mon May 05, 2014 10:26 am
Hi Mike
Excuse my ignorance on this injector topic, but how thick is the copper sleeve and how many times could this process be done. I'm thinking once or twice on the lifetime of an engine.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Postby J44EAG » Mon May 05, 2014 2:52 pm
Assuming the sleeve on the engine I was working on is uniform in thickness (about 3mm on the marine Volvo) I would think the sleeve could be reamed four or five times before needing replacement. That would probably equate to about the same number of rebuilds depending of course on whether parts for the unit were still available.
Most of the reaming effort was expended of cracking through a bout a half mm of solid carbon. One the copper was hit, only a dozen or so light rotations were needed just to remove a fine micky whisker of copper and restore the flatness and surface of the base of the sleeve. If it needs doing again in thirty years time, that will be someone elses problem!
Very glad I have this tool.
jeff1954
Postby jeff1954 » Mon May 05, 2014 3:35 pm
Cheers Mike
That's something else I've learnt.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
