Door card clips.
Door card clips.
Postby J44EAG » Mon Apr 07, 2014 11:24 am
These often broken parts are readily available from a supplier in this link.
http://www.ebay.co.uk/itm/JAGUAR-TYPE-D ... 43c6a74b65
oldtimer
Re: Door card clips.
Postby oldtimer » Tue Apr 08, 2014 9:25 pm
Mike ,
That useful, have you got any yet? and have you tried them?
I seem to recall you saying that a door card needed some attention.
While on the subject - both you and Brian have written about door locks and breaking into the car etc. My question is, what was the general condition of the metal work inside the door regards corrosion and deterioration ?
P
Martec
Postby Martec » Fri Apr 11, 2014 11:38 am
Hi Oldtimer, back on the site to wind a few more up!!!
The interior of the doors were perfect, but it didn't stop me adding some dinitrol cavity wax for the future.
oldtimer
Postby oldtimer » Fri Apr 11, 2014 10:08 pm
Hi Martec,
Glad to see you back ,Yep, that's right a wooden spoon in one hand and a sharp stick in the other!!!!
Door internals perfect, that sounds comforting. Can't say I'm too excited about taking the door cards off for wax oiling if no good reason. See if we get any other contributors
Oldtimer
Martec
Postby Martec » Sat Apr 12, 2014 9:00 am
Removal of the door cards is simplicity itself. the only snag is removal of the plastic cup thing behind the interior door opener. It is clipped into place and I found the easiest way to remove them was to used broad bladed scrapers wrapped in cloth and gently ease the edged up until the clips popped. Then wriggle the cup off the door open/lock levers. Remove the two screws in the centre of the door under the little rubber mat. Then gently and steadily pull from the top and the plastic clips will disengage. I put copper-slip on these clip/pins and then carefully lined them up and pushed them home one by one. Don't do an 'Oldtimer' and give them a sharpe slap or they will snap off (don't they!!!)
