well, it does in my '89 V12
good luck
Oh right! The wiring, relay and fuse must be man enough then to take the extra load. Good old British quality! That is really really easy then. Might as well do it as I've got the fan already. Thanks!just splice into the wire for the aux fan , the pump cover mounted stat works the fan no problem , and also provided run on after the engine is switched off , until the stat says thats enough.....
good luck
