Convertible - Power Hood Failure
keithmervyn
Postby keithmervyn » Mon Oct 02, 2006 5:37 pm
Help Anybody ?? My 4.0 litre's power hood has always worked perfectly, but suddenly it will lower fine, but not raise again. I have used the "manual" pump setting to heave the hood back up, but of course the side windows remain open (and its going to rain !).
Any obvious reason why it will lower but not raise (don't be rude), can't be the fuse or I assume it would do neither ?
Keith MR
dhdove
No Hood
Postby dhdove » Tue Oct 03, 2006 2:47 pm
Keith
This sounds like a bit of an emergency, unless the car is for high days and holidays only. I would suggest you go straight to the horses mouth ie Dave Marks 0115 982 2808.
Good Luck
DH Dove
XJS Bulletin Board Moderator
Postby ptjs1 » Tue Oct 03, 2006 6:53 pm
Keith,
A couple of things you might check:
- the hood switch. Like the window switches, the hood switch can be prone to gumming on the contacts. Try opening it (VERY carefully - lots of springs and little pieces!) Even just spaying electrical cleaner spray into the switch whilst still assembled can make a big difference.
- the control module. Mounted in the boot. the switch passes a signal to the control module which then passes current to the hood UP and DOWN relays and thence to the motor and pump.
- the hood UP Relay. Mounted in the boot with the control module. There are separate relays for up and down action. I think the UP relay is the third one from the right. Check that current is passing to and from the relay as appropraite when the switch is being operated.
All of this might help to eliminate whether the problem is at the switch, control module, relay or post-relay.
Good Luck
keithmervyn
Power Hood Failure
Postby keithmervyn » Tue Oct 03, 2006 7:57 pm
Thanks Paul
I had the switch out today, gave it and the bullet sockets a good twiddle and, hey presto, got the quarter-lights up. Put the switch unit back, put the hood down, then up again, fine - just once, then it seized down again!
More switch twiddling, considerable, before once again, everything sprang into life. Now all is closed up, it can stay that way until next April !!
Nice to hear positioning of relevant modules & relays - I guess they and the switch will all need a professional check-out next spring. Not many of us XJS-forum members need to worry about this problem !
My tip for all XJS power-hood owners is to keep a weatherproof car cover in the boot, at all times. The stuck open quarter-light problem is SERIOUS when it rains. Thanks again
Keith MR
jagcat12
Postby jagcat12 » Mon Sep 03, 2007 5:10 pm
My hood failed to raise recently and a way to test is to disconnect the wiring connector from the hood switch and connect the wiring to one of the electric window switches which are the same type.
When I did this the hood operated perfectly pointing to the hood switch
(it would lower) Cleaned up the switch and reconnected all working again
Dave
