Postby Martec » Mon Aug 26, 2013 10:43 pm
Going back to the original post, there is a reference to the interior lights staying on for a very long time.
From my fiddling about with the door locks, each door contains a switch that tells the Rear Electronic Control Module that it is shut and the interior light will dim quite quickly, if not then the light will stay on for something like 20 minutes until it finally goes out. This switch seems quite robust (unless you tread on it when its opened up), but maybe part of your problem.
As Mike has said a tired battery is not good for the electrics, one car we went to look at had a flat battery and was jump started from a battery pack and a lot of stuff didn't work (A/C) until the voltage came up. Quite heartening to see after all the stories of disaster on multi ECU cars.
